23mm in FF mode and cropped in
slightly on the K-1;
I tell you I really love this lens on the K-1... dare I say it that it feels
better in performance than sitting on the KP! It's not that the KP is a slouch but you get a wonderful additional DoF punch on the K-1 than what the KP can manage due to sensor differences. Of course you do have some significant considerations such as;
1) you're really only getting usable 3:2 images between 23-37mm (even with vignette removal you probably want to crop in slightly till the image is around 30mp).
2) you can perhaps manage one filter on the lens, certainly stacking filters is not an option and makes matters worse.
3) at 20-22mm and 38-40mm it heavily vignettes but 1:1 shots are plausible and even 4:3 if again you're willing to crop in slightly.
4) you're actually getting 20-40, not 30-60 FoV (unless you use crop mode of course)
Personally I think of things from a FoV perspective. If I want a nice 28mm non vignette shot then I would shoot at 23mm and crop in. Actually I use it a lot at 23mm and do that. I do have a F28 but it is not WR, has noisy AF and is very bad with flare (like not in a cool flare way but nasty flare), so the 20-40 was used a lot on this wedding day. I simply dial back a bit when thinking about the shot. Want a 35mm shot? set it to 31mm etc etc.
I actually found a neat trick recently that I wasn't aware of, I made this video to demonstrate it;
So that's how I get quickly accurate with the focal length set.
