Originally posted by Dewman I usually have no problem removing the base plate, but recently, I removed two of the three screws but the third would only spin and spin and NOT unscrew from it's hole! I finally gave up and used a Dremel Tool to grind down the pin so it wouldn't hang up. Only time I ever had THAT happen! Very frustrating.
If there was a way to put a little gentle pressure from inside the base plate, pushing outward, the screw might have backed out. Then of course, you would probably never get it back in. Actually, a good quality glue is very capable of holding on the baseplate, although I really prefer screws since my Canon FL 55 mm f 1.2 fell off when the glue gave way. Right now I have a little problem with an Auto Yashica-DS 50 mm f 1.4 screw mount. It has no screws on the base plate, and there are only three tiny screws up on the barrel of the lens forward of the aperture ring. These appear to be standard slot screws, but about one-third the size of the regular baseplate screws on other lens I have worked on. Maybe the drimmel is the answer; as small as these screws are, it seems to me that there is a high probability of stripping the screws.
