Show Printable Version 655 Likes Search this Thread
04-06-2017, 11:40 PM - 1 Like   #376
shiner's Avatar
With DA*300 tonight. I think high winds aloft made it a little fuzzy.
04-20-2017, 01:37 PM - 1 Like   #377
Male Sparrow
150-450 plus convertor
PENTAX K-3  Photo
04-21-2017, 04:54 AM   #378
audiobomber's Avatar
Wonderful detail and great colours royd63uk, but I don't care for the bokeh. Would you be able to post a shot with the 150-450 with and without TC for a bokeh comparison?
04-22-2017, 02:51 AM - 8 Likes   #379
k-1 & DA300 & TC1,4x
05-17-2017, 05:39 AM   #380
Hello.
Is the combo K-5 II + HD Pentax-D FA* 70-200mm F2.8 ED DC AW compatible with the TC ?
Any sample images ?
Thank you
05-17-2017, 05:44 AM   #381
devouges's Avatar
My first test shot with the DA*300. Hand held.
I LOVE my DA*300 ! ! !
05-17-2017, 09:57 AM   #382
QuoteOriginally posted by audiobomber Quote
HI Dan
I will try to get a shot without the convertor, I think the bokeh is due to slight movement also as this was hand held
Roy
05-17-2017, 11:44 AM   #383
QuoteOriginally posted by royd63uk Quote
HI Dan
Roy
I don't think shake was an issue, because the foreground is tack sharp. I am curious to know if the bokeh is normal for this lens or a characteristic of the lens + TC.
05-17-2017, 12:30 PM   #384
Ok Dan
Will tke a couple of photo's to compare
Roy
05-17-2017, 05:32 PM   #385
Weevil's Avatar
I noted that the DA300 + HDTC hase a more nervous bokeh than the DA300 itself... the 150-450 already have a nervous bokeh without TC, and anyways, TC's would normally just proportionaly increase any bad rendering...
06-06-2017, 08:29 PM   #386
A bird-in-almost-flight with the *300.
10-22-2017, 12:51 PM   #387
Seeker of Knowledge
aslyfox's Avatar
Red Winged Black Bird perched on a cat tail
K 3 + Smc PENTAX-DA L 55-300mm F4-5.8 ED + HD Pentax-DA 1.4x AW AF Rear Converter
hand held, natural light
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
11-14-2017, 08:47 PM   #388
Weevil's Avatar
(X-posted )
This immature dark morph Snow Goose have drawn the attention of bird watchers because it has a pale tip of its beak. It's probably just a simple genetic aberration
K-3II + DA300 =HDTC1.4x
(heavy Crop at 1:2)
Oie "bleue" juvénile spéciale / Special Immature Blue Goose
11-14-2017, 11:41 PM   #389
Weevil's Avatar
QuoteOriginally posted by exnito Quote
Hello.
Any sample images ?
Thank you
Hi, I think nobody answered your question, which answer is unfortunately no... the HD TC 1.4x is not FF compatible. It would work, but you'd have severe vignetting.
However, it would work, and could be ok if your subject is pretty small on the sensor (I'd say something like1:4 crop at least) and accordingly that you have lots of spare Mpx to crop to your subject, for example from a K-3xyz
Hope that helps...
Edit: Just saw you have the K-5II... so it would not be an issue, my answer was for a K-1 Body with that combo...
11-15-2017, 04:45 AM - 1 Like   #390
Seeker of Knowledge
aslyfox's Avatar
Hello.
Is the combo K-5 II + HD Pentax-D FA* 70-200mm F2.8 ED DC AW compatible with the TC ? . . .
QuoteOriginally posted by Weevil Quote
Hope that helps...
I don't have a K 1
but it does have a crop mode and as I understand it, the DA 1.4 rear converter will work with the K 1 in crop mode
____________________________
the rear converter does work with the D FA * 70 - 200mm 2.8 lens
this link to part of the " in depth review " indicates how it works with Pentax camera bodies and lenses:
Pentax-DA 1.4x AW AF Rear Converter Review - Specifications | PentaxForums.com Reviews
this link shows that certain Pentax camera bodies require a firm ware update for full capacity:
New Firmware Adds Support for Pentax Teleconverter - Firmware Updates | PentaxForums.com
I have used it with my K 3 and K 5 II without any problem
300mm, af rear converter, bird, club, converter, converter 1.4x, f4, flickr, harm, hd, hd pentax-da af, iso, k-3, k-mount, killdeer, lens, love, migration, moon, pentax hd pentax-da, pentax lens, philip, post, sdm, shot, shutter, slr lens, speeds, sr
Stacking HD-DA 1.4x Rear Converter AW quarc Pentax SLR Lens Discussion 18 12-13-2015 11:44 PM
HD-DA 1.4x Rear Converter AW+ (D)FA 100/2.8 = FA200/4? zantaphia Pentax SLR Lens Discussion 7 04-06-2014 11:41 PM
HD Pentax-DA 1.4x AW AF Rear Converter v.s Kenko Pz-AF 1.5X Teleplus SHQ Unregistered User Pentax SLR Lens Discussion 19 04-03-2014 02:52 AM
Is there any info about PENTAX-DA 1.4X REAR CONVERTER SDM? ogl Pentax News and Rumors 18 10-01-2009 06:17 AM
All times are GMT -7. The time now is 08:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
