Originally posted by Duh_Vinci Edri, I think you will enjoy it quite a bit! I originally started exactly as yours, but ended up buying inexpensive m42 to m42 focusing helicoid from ebay, so I still have "semi-permanent" mount for the moment, I've ordered step down ring adapters to make it fit better and to use the hood (this lens neeeeeeds it badly imo). So for now it's pretty much same distance as your, but more often than not, I use extension tube on it to get close focus.
Once I get the rings, I will post detail pictures of the "rig"
Please, all, post photos with these repurposed lenses!!!
Kind regards,
D
Originally posted by Jean Poitiers Franken-lens-ed a new one today. Torn down an Isconar 135/4 to have the 14 blade aperture and mount it on the Russian bellows with the Malik Triolam.
Crappy weather, but ran outside for a few quick test snaps @ f/5.6, I think. More later and maybe with a different projector lens ... J
Hey Gentlemen,
I have just purchased a few projection lenses:
1) Dukane Projection Lens - 3", f 2.5
2) Leitz Wetzlar Leica Colorplan Projection Lens 1:2.5 / 90mm
3) Pentacon AV 2,8/80mm (Diaplan 2,8/80)
4) SHORT DIAPLAN 80/2,8 projection LENS
I have been searching all over the internet using different terms to try and figure out how to use these with a DSLR.
Could you both explain a little more (pictures are great too), about how you use these?
I actually don't care as much about adjusting the aperture as I do about being able to focus, and being able to attach it.
Jean Poitiers - I like your idea of tearing down and using old lenses. Would any old lens work? What are the things I need in an old lens to adapt the projection lenses I've listed?
Thank you VERY much.
Rick
