Show Printable Version 635 Likes Search this Thread
09-15-2018, 08:12 PM - 5 Likes   #406
Thagomizer's Avatar
Our next contestant:
Staeble-Werk Stellar 85mm f2.8
Mounted on a basic screwmount bellows via 49mm reverse adapter and 37-49mm stepping ring (epoxied to the lens itself), with an extension tube to allow clearance of the flash housing.
Minimum extension:
...and a shot at minimum extension: (approximately x.6)
Maximum extension. Not the easiest hand-held combination I've ever used...
Approximately x1.8
In the field.
The bamboo plant at work offered many possibilities. Studio-ish, or at least indoors, so no breeze. Still handheld.
Chlorophyl cobra:
Even the gravel the bamboo is planted in held interesting secrets:
I'll have to try it directly on the camera to see what I get. Presumably, less magnification and longer focusing distance.
09-16-2018, 12:04 PM - 4 Likes   #407
Audi 5 cyl's Avatar
I am learning a lot following this group and thank you all for your great efforts to make it better. Seeing the great results you've got using these projector lenses, you've motivated me to go out today with a couple of my all time favorites, Benoist Berthiot Panastar S and Leitz Wetzlar Colorplan. Thank you for that.
Here are the results:
Zinnia haageana
by Marko Jankovic, on Flickr
Zinnia haageana
Zinnia haageana
09-17-2018, 10:54 PM   #408
Jean Poitiers's Avatar
QuoteOriginally posted by Thagomizer Quote
Great ! Those are very good and thanks for your informative post.
Nice idea for the stepping ring ... another solution !
Hope to see more soon ... Cheers, J
09-17-2018, 10:55 PM   #409
QuoteOriginally posted by Audi 5 cyl Quote
Very nice, Marko !
09-18-2018, 09:20 PM - 4 Likes   #410
Jan178's Avatar
Cold starts to creep in
K-70, Maginon 85mm f/2.8
[IMG][/IMG]
01-23-2019, 10:09 AM - 1 Like   #411
Just some FYI here ... This $6 Flea Market Projector Lens is Surprisingly Great for Portraits
And I promise to get out soon and shoot a lens creation on the K-1 ! Cheers, J
02-11-2019, 07:11 PM   #412
shiner's Avatar
How do you mount these lenses? I'm thinking of getting a Diaplan 80/2.8
02-12-2019, 07:53 AM - 3 Likes   #413
Thagomizer's Avatar
QuoteOriginally posted by shiner Quote
What I've done is to epoxy an appropriately sized step up or step down ring to a lens in such a way as I can mount it to bellows or extension tubes using a reverse adapter, using other rings to go between the reverse adapter (which is male threaded) and whatever diameter ring I have on the projector lens Which I usually have with female threads facing back towards the direction of the camera).
See here, here, and here for some examples of how I put stuff together. It's not elegant, but it works. Other people find other solutions. It all depends on what bits you've got, what bits you can get a hold of and what's going to work for your shooting style and subject matter. Some people use electrical tape or epoxy glue. Others have access to and talent for metalwork on a metal lathe. Start experimenting and sticking stuff together and see how -or if - it's going to work.
Read more at: The "Projector Lens" Club ... - Page 28 - PentaxForums.com
Last edited by Thagomizer; 02-12-2019 at 07:58 AM. Reason: Added quote, fixed links
02-12-2019, 09:40 PM   #414
shiner's Avatar
Thanks for the tips! I'll see what I can do...
02-13-2019, 08:06 AM - 2 Likes   #415
My favorite is a Russian macro bellows that the front M42 mount comes off so there's a really large opening in which to slide a lens ... any light leaks are fixed by using tennis racket grip tape around the barrel of the projector lens. See first page plus other later posts ... The "Projector Lens" Club ... - PentaxForums.com
Also, I have "Fraken-lensed" by inserting the projector lens into de-glassed zoom or fixed focal length lens ... my favorite is a de-glassed and partially front portion removed Helios 44 ... because you have an iris in the set-up ... here's some other ramdom images from old attachment files.
02-15-2019, 02:09 PM - 1 Like   #416
Just FYI ... here's the Russian bellows that I prefer. The chrome M42 front ring comes out leaving a large opening to insert a large diameter projection lens.
I purchased a second one recently off of fleaBay pretty cheap ... the postage from the UK was more than the purchase price. See below ... & cheers, J
04-27-2019, 03:28 AM - 4 Likes   #417
My "quilt study" efforts ... this is what you do when you are rained in at an arts & crafts fair.
Leitz Hektor 8.5cm f/2.5 mounted in a de-glassed and half body of a Helios 44-2 lens ... basically it's a M42 helicoid and this will focus to infinity. (x-post from K-1 thread)
05-02-2019, 12:22 PM   #418
Just FYI ... Projector lenses are showing up on eBay. Here's one fitted into a halved Helios 44-2 body ... there are a few others on this site.
PROJECTOR PROJECTION 16KP LENS F/1.2 50mm FOCUSING HELICOID SONY E MIRRORLESS | eBay
05-14-2019, 09:39 PM - 2 Likes   #419
Jan178's Avatar
reflecta Agomar 90mm f/2.8 on K-5
I think my Maginon 85mm is more pleasing but more testing needed
[IMG][/IMG]
05-15-2019, 07:57 AM - 5 Likes   #420
Jan178's Avatar
[IMG][/IMG]
afternoon, biometar, body, bubbles, club, cook, flickr, focus, front, helicoid, hood, infinity, k-mount, k110d, lens, lenses, march, mount, pentax lens, pm, post, projector, salut, samples, shots, slr lens, surface, test, thanks
DA 40 XS the "Flat Wonder Club" HoBykoYan Lens Clubs 237 12-15-2023 04:36 AM
The "rediscovered" lens club slip Lens Clubs 23 04-06-2023 12:06 PM
The "Cheap AF 28ish-80ish zoom lens" club Steve Beswick Lens Clubs 157 02-27-2020 02:01 PM
A German "Origins" Lens Club Merger? les3547 Pentax SLR Lens Discussion 13 07-12-2011 04:36 PM
The "pleased on the purchase of a new lens" club TKH Pentax SLR Lens Discussion 8 03-22-2010 03:12 AM
All times are GMT -7. The time now is 08:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
