Originally posted by jsherman999 Marc, are you doing something different in PP with sharpness now, or downsizing method? Those last three shots and the shot of that cat you took with the DA 70 in the other thread just have perfect sharpness. And the color in that M 28 shot is also perfect (on my monitor at least).
Interesting you should ask that!
I haven't actually changed anything about my sharpening settings - all of the aforementioned shots just use the defaults that ACDSee comes up with when camera sharpness is turned up a notch. But I *have* recently been experimenting with color and contrast. Not that I haven't always played around with those, but starting with that batch of shots, I've been trying out a new method.
I've always noticed ACDSee's default conversion of a RAW image is contrastier than the camera-embedded preview (using Natural mode and all other settings except sharpness at default; not sure how it would look with Bright, or with any of the options you normally suggest). On many images - I like ACDSee version better (more "pop"). On others, it's a toss-up. But for some - particularly sunlit scenes - the contrast in ACDSee's conversion would tend to make shadows go too dark. And ACDSee tends to render "landscape greens" a bit unnaturally (too cool and too intense) by default as well. So I'd play with contrast, curves, WB, saturation, hue, and/or vibrance on an ad hoc basis on images where this bugged me.
What I just did for the first time a couple of days ago is to create a set of customized pre-processing curves for ACDSee to use in place of its standard (camera-specific) versions. ACDSee doesn't actually let you change the "default" conversion, but it does allow you to "manually" select your own pre-processing curves. I created a preset on the RGB channel that bumps the shadow levels slightly, then in the individual color channels, pushes R a little but pulls back G and B slightly. So for images taken under sunny conditions, I am now applying this preset rather than starting my custom PP from the default conversion. Realistically, most images taken in sunny conditions weren't getting any PP at all (although perhaps most of the ones I've actually posted got at least a little shadow lightening), so even if my old methods would have been *capable* of rendering images similarly to what my preset does, I wasn't really doing this.
I suppose it's possible that some of these changes would have an effect on perceived sharpness, but again, none of these are actually processed any different in that respect. So it's possible that it's complete coincidence that you noticed a change right when I changed something. But it sure makes me go "hmmm".
BTW, I suspect I actually went too far with my preprocessing curves, as some images I apply them too look *too* warm and have their contrast pulled back *too* far for my tastes. However, if I can assume your comments are anything but coincidence, I'm probably on the right track :-)
