Originally posted by 8540tomg Quite a story Albert.
To bad the cougar had to be put down. Not a perfect solution but better that than a child being mauled or killed. I guess they didn't have a dart gun available to tranquilize the cat.
That was a nice image you managed with the M 400 bye-the-way. I suspect 400mm didn't seem quite long enough at the time.
Tom G
Hi, Tom. The decision to kill the cougar was based on the human threat and that the animal was in a back yard (50x100 foot lot - not a large yard at all) with humans present, and did not leave until the boy made himself big. Even then it merely hid behind a garden shed on the same lot. This behaviour indicates serious trouble in the future. The local Conservation Officer referred the situation to the RCMP.
Actually, the 400 was a bit long later - the old M won't focus any closer than 16 feet, so I did not get any snaps of the RCMP removing the body. A 50 foot wide lot does not give a large field of view with a 400. Given the option again, I would probably put on the 50-135 + 1.7X, but would have had to shut off the AF, obviously.
