Originally posted by Jonathan Mac Looks good. You´ve successfully captured the 3D rendering that the 85/2 does so well. What apertures were used for these, if you remember?
Thanks, I never realised the aperture would not have been recorded - was just imagining when i open my raw i will come to know - until you asked. Had I known I would have marked it precisely which I will do next time for sure, having said that I am sure the first image was shot at f8, but from what I could recollect 'bloom' and the 'recycle' were at f2.8.
I have some questions and concern: What you see is after PP, isn't it possible to get this straight out of the camera - it had always been around -EV, I am also a newbie to manual so that is also a big reason. Since I used PP somehow I am fully not happy in what I have done - I want that effect straight out of my first click.
Also, I am noticing two things in the 'M' lens usage on my dslr, just wanted to know it that is normal. I am able to meter on the press of 'green' button and noticed the same happens when i press the '+/-' button - is this normal?
Also generally in Manual mode while using a for example the DA lens, I can see the EV compensation scale reading. But with 'M' lens the EV comp scale is there but no reading - so while adjusting the shutter speed or aperture i can't see anything on the scale, is this also normal? ( I presume so)
thanks
S
