Originally posted by paulh Rick - looks like you're able to squeeze every drop of performance from that 40-80! Nice job.
repaap: Nice ones, the M75-150 is an incredible lens. Sorry to say I don't give mine anywhere near the use it deserves
I should get it out right now while I'm thinking about it!
Thanks Paul and I even have to admit that last shot with the 40-80 looks good
But I have to give repaap credit, who also uses the 40-80, for giving me advice and motivation on this quirky lens!!!
Originally posted by Designosophy When using an M zoom, what do you set the focal length to? Do you guess where you'll be doing most of your shooting and plop it in the middle?
If there is a setting right in the middle of zoom I go with that, otherwise I will pick the next higher FL available. I will also, for instance on the 75-150 set it at 120mm for both SR and my way of remembering which lens I used (since I do not have a prime 120). The only time I've noticed any problems with SR and FL input, I was using a 35mm prime but forgot and left my SR at 120m it seemed most of my images were a little blurry...
