Originally posted by el baroda Hi. I am seriously thinking of getting an old Takumar 135mm f/2.5 lens but am not sure if it is a good move since I already own a modern Tamron 18-200mm lens. Can someone tell me if there is a noticeable difference in IQ between the two lenses if the latter is set at 135mm, assuming that available lighting is adequate? Should the former, being a prime lens, be better? Comments and suggestions will be much appreciated. Thanks and regards.
As others have said, it really depends on what you consider to be important about image quality. I owned the Takumar (Bayonet) 135 f/2.5. It's sharp - sharper than most zooms at that focal length, for sure, particularly at equivalent apertures. I have little doubt that it will be sharper than your 18-200 at 135mm. Plus, even with the K-5, high-ISO noise is an IQ killer. I love my Tamron SP 24-135, and it has great IQ wide open, but I would not use it indoors without a lot of sunlight or a flash. Even f/2.5 is slow for lamp-lit indoor lighting, but it's a heck of a lot better than f/5.6+. A 135 will give you really nice out of focus areas, as others have mentioned, particularly at large apertures.
Since the Takumar (Bayonet) is not multicoated (like the A 135 f/2.8 (which I've owned), or K 135 f/2.5, or some M42 Takumars), you will experience more loss of contrast and saturation in high-contrast situations. But its bargain price reflects this. Do you find yourself using your 18-200 a lot at 135mm? I think that's an important question when considering a prime. If you often use 50mm, and you don't have one, a 50mm f/1.4 or f/1.7 is a great starting point for fast primes. The M and A variants have great IQ and cost less than their AF equivalents. The M 50 f/1.4 was my first prime, and it really spoiled me with its fantastic IQ, speed, and bokeh.
