Originally posted by kcobain1992 Thought this may be helpful to someone:
The only thing that works for me off Flicker, is to right click on an image, select the size I want, then Copy Image (not URL), then, paste the image directly into the message window. If I select BB code or HTTP code, I either end up with text or a little white square. Using the icons didn't work either.
As for uploading from the computer, it is hit and miss even when downsized correctly. It works sometimes, and others the upload screen goes blank after a few moments.
What needs be explained, and I just discovered, is that when the BB code is uploaded via the icon, one only sees text - UNTIL - it is posted. This is unlike posting the image directly, when the image appears instantly.
