Originally posted by Jorgario Thanks southlander for taking your time and explaining me the cons of the M 135mm f3.5. I really appreciated that. Definitely the purple fringing is to avoid and not desirable ... As you mention the chromatic aberrations, I am adjoining the original in order you can help me to see if there is in fact a CA (I may excuse with other users of this thread for continuing showing not a nice picture) ?? Cause I think the purple and green come from the original sand color and grass color of the out of focus backwards mountain and a
color oversaturation I did ...
Thanks again for your advices,
The re-posted photo looks a lot cleaner. Nothing too obvious. I thought I saw some purplish colouring on the end grain detail towards the front of the fence post on the shot you first posted, but it looks like your post processing was the main contributor to what I thought I saw.
Many lenses can have a touch of purple fringing at wide apertures on high contrast edges. Good lenses get rid of it pretty quickly on the first click or two of stopping down. Modern lenses with automatic profile corrections of distortion and aberrations tend to hide it with the processing into JPEGs in camera or when uploaded to computer software. My M85/2 is a quality lens but can produce an amazing blue fringing outdoors at F2, heavily reduced by F2.8 and gone by F4. I really think F2 on that lens was designed for indoor portrait use only where lighting can be much more carefully controlled and high contrast edges avoided.
I don't have a really clear recent example of CA with the M135/3.5. The last lot of photos with it were generally pretty good (I must have been more careful with focus and background choice). If you look at this post on my blog
A wet and rainy day and scroll to the pelicans with the jetty in the far distance, you can see some green CA around the jetty pylons (a close look and you can see I have used Lightroom to desaturate it to make it less obvious, with the side effect of producing an odd halo around the pylons). The top group of photos down to the bright orange seaweed were all with the M135/3.5 in interesting but rather low lighting levels on a late winter's afternoon.
The out of focus chromatic aberrations (CA) are more obvious with this shot taken with my M200/4 at either F4 of F5.6. I don't mind manual lenses but I do miss the EXIF details...
If you look at the out of focus parking zone signs behind the cupcake signage you should be able to see that the white/dark boundary around the sign is quite green fringed. The margins of the fluros upper left also show it as does the Colonel's chin. From memory the area out of focus but in front of the focus plane would show blue/purplish fringing. Not violently obvious and distracting here but out of focus trees with masses of bright/dark boundaries can get pretty ugly, so good to avoid.
