12-24-2014, 09:44 AM   #4861
Cabessius's Avatar
QuoteOriginally posted by baro-nite Quote
Nice job -- strong composition with those alternating blocks of complementary colors.
Thanks for commenting, I find the M100 f2.8 a great lens, compact, fast, and with great IQ.
12-24-2014, 09:50 AM - 1 Like   #4862
paulh's Avatar
M75-150/4 (crop)
12-25-2014, 11:11 AM   #4863
You do want to be careful trying this, but it's designed to be changed by the user, i.e., no special knowledge or equipment required. The main thing is not dropping or scratching the screen. The instructions on focusingscreen.com are good enough to get you through it.
I'm not saying you should change yours, however. I happen to like the S-type screen but not everyone does. It gets darker than the stock screen with especially slow lenses, and some have claimed metering inaccuracy.
Diopter is unlikely to be the issue. If the diopter is off, the entire viewfinder will look out of focus.
Here's how I tested focusing screen alignment. Camera on tripod. Target is a printed page, camera at an angle to it so only a few lines are in focus. Looking through the VF, note which printed lines are the start, middle, and end of the in-focus area. Make an exposure and then compare. I suggest an aperture of f/3.5 or so, so that the VF image has a similar DOF to the output. Although you should probably also make an exposure wide open, to make sure focus shift isn't an issue (i.e., focus distance changing as lens is stopped down).
Hello...
Sorry for being long to answer...
i made many try and finally i realized :
1) Diaopter was totally OK --> problem did not come from there...
2) Many photos i made inside were really different on computer screen in comparison to what i saw with eye in the camera (K5)
3) Today i made a try : i realized that focus was always in front of the zone that seemed to be OK on my eye --> so i used the front-back focus option in the menu of the K5 --> i tried for example at +5 --> all photo were much better.
--> i think i should use an appropriate grid to determinate what is the best "front/back focus number" in the menu of the K5....when focus is ok, photos are really fabulous with this 50mm f1,4 (i mostly use it inside home at f2)
Thank for you help !
Lionel
---------- Post added 12-25-14 at 07:20 PM ----------
thank you for your help...
i am thinking now about changing the focusingscreen but dont know which one to take...
moreover : when i will use another lens : should i change focusing screen for each différent lens ???
Lionel
12-25-2014, 05:15 PM   #4864
baro-nite's Avatar
Changing the focusing screen is not something I'd want to do that often. Glad you have your focus issues sorted out, although the fine focus adjustment is for autofocus.
12-26-2014, 05:31 AM - 3 Likes   #4865
Lauke_101's Avatar
With the 135 f/3.5. This lens has impressed me quite a few times already
12-26-2014, 02:28 PM - 1 Like   #4866
QuoteOriginally posted by Cabessius Quote
Another one, this afternoon with the SMC Pentax M 100mm f2.8 @f2.8
1/100s
ISO 100
Very likeable picture here. The 100 is so easy to like-it really delivers whether portrait type stuff or landscape work. I've sometimes found myself thinking that the 100 M 2.8 is the best lens I've ever shot (I used to shoot the Canon 100 2.8 macro with floating element-a very heralded and great lens that's hard to beat). Takanami's numbers show that at f16, of all things, this M 100 is in the company of the sharpest of the sharpest lenses. He flat out says it's in the top company of elite lenses at that stop. I skeptically tried, not long ago, a number of shots at f16 and found that Takanami is absolutely right. The lens is spectacular at that f stop. It really shifts to a new level of sharpness at that point. That's kind of strange behaviour for a lens in my experience since diffraction usually takes a small toll by then. It's phenomenal as an all around lens-and is very light and compact. It can more than take the place of a great and expensive fast 85 and fabulous hulking 135 in my opinion. I kind of wish it had the built in hood like the 135 and 200Ms though. Other than that, it's just about perfect.
12-26-2014, 03:49 PM   #4867
Cabessius's Avatar
QuoteOriginally posted by mglowe Quote
... I kind of wish it had the built in hood like the 135 and 200Ms though...
Thank you very much for your words, it would be perfect with a built-in hood. As a work around I use a 49-28 step-down ring permanently attached to the lens. It doesn't vignette at all and does the job.
12-26-2014, 05:08 PM   #4868
OK, I'll try the step down ring approach. Does it work in bright sunlight as well as a traditional hood?
12-26-2014, 09:19 PM   #4869
arnold's Avatar
QuoteOriginally posted by Lauke_101 Quote
Well done!
12-27-2014, 02:19 AM   #4870
Cabessius's Avatar
Yes. It works.
I also use the same thing with my 50's and 55's (49-28 with the M and 52-28 with the K of course)
Didn't try with the 40
With the K 35mm the 52-28 vignettes so I use a 52-37 instead
And with the 28-24mm, a traditional petal hood.
12-28-2014, 11:42 AM   #4871
paulh's Avatar
I was revisiting some of my older shots with the M50/2, and coming to realize what a nice old lens it is
slight crop:
12-29-2014, 11:08 PM   #4872
arnold's Avatar
QuoteOriginally posted by paulh Quote
Nice picture. Yes, a perfectly fine lens, and appropriately used, would not limit a good photographer; by the same token a rare super expensive lens is unlikely to help a poor photographer. It's the photographer who makes the picture..
12-30-2014, 01:02 PM - 7 Likes   #4873
turkiye2turkiye's Avatar
K5IIs+ M150f3.5 ( f8, 10 sn), Bosphorus Bridge, Istanbul
12-30-2014, 01:31 PM   #4874
Pepe Guitarra's Avatar
QuoteOriginally posted by turkiye2turkiye Quote
You are too good!
12-30-2014, 01:33 PM - 1 Like   #4875
Jean Poitiers's Avatar
Excellent. You should submit this to the Pentax Forums Exclusive Gallery ... you'll get a top judge vote from me. TFS, J
28mm, background, bokeh, camera, city, colours, contrast, dust, elpolodiablo, flickr, focus, hood, k-5, lens, lenses, light, m50/1.4, park, pentax, pentax lens, photo, picture, pm, post, pp, ps, shot, thanks, time
The A Club jake.astig Lens Clubs 3824 1 Day Ago 11:04 PM
D-FA WR Club Rico Lens Clubs 640 4 Days Ago 05:43 AM
The F Club! jsherman999 Lens Clubs 1057 11-22-2021 03:26 PM
Ltd club, here I come axl Lens Clubs 21 12-12-2010 03:06 AM
In the club again metroeloise Post Your Photos! 4 10-20-2008 08:59 AM
All times are GMT -7. The time now is 08:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
