Originally posted by iheiramo The shot is nice, but it doesn't show on PF. The link to Ipernity works. To get the shot visible you need something like BBCode on Flickr or direct address of jpg image. I believe I've seen shot from Ipernity here before, so it can be done
Edit: At least I cannot see the image. Don't know if it's visible for others.
I can see it. The problem is with your settings and you're not the first to have it. I experienced it with one user's posts a while back and had to go to my settings and turn something off and back on again, unfortunately I don't remember which setting it was.
Regarding the ongoing debate, there are very few lenses which don't have a sweet spot (assuming this means optimum sharpness) around f/8, though with modern digital sensors I believe that with sharp lenses diffraction has a small impact at f/8 resulting in f/5.6 being the sweet spot. But any lens that doesn't produce good, sharp images at f/8 is a very bad lens.
Personally, it's hard to think of many lenses which don't perform very well at f/8. The exceptions that come to mind are super- and ultrawide lenses such as the Sigma 10-20mm f/3.5, DA 15mm limited and Cosina 19-35mm, which all benefit from stopping down to f/11 to maximise corner sharpness, though this is possibly at some expense of centre sharpness due to afore-mentioned diffraction.
I don't worry much about these things - I know which apertures I'm happy to use my lenses at depending on the results I want. For example any of the 50/55mm f/1.7 or 1.8s will be very sharp by f/2.8. This isn't based on them being in the M, or any other, series, it's just a question of knowing your lenses.
