Originally posted by UserAccessDenied Of these cameras, which has the best high ISO performance?
I'm considering a second body to accompany my K-30... Debating between the K-5iis and the K-3.
Any preferences for using with the Bigma?
The K-5iis has a better looking high ISO image out of the camera, but the K-3 images can be made to look equally fine with only slight noise reduction in post.
The Bigma performs equally well on both bodies, neither gives any type of advantage.
The K-3 has better AF in all areas than K-5iis.
K-3 has faster performance than K-5iis.
If you like and use the focus peaking in K-30 you can only get it in K-3 not K-5iis.
At this point between the two I would go for K-3.
Btw these bodies are a big step above the K-30 so it will become the backup.
I think you will quickly prefer using these instead as your primary body even if they are a little heavier.
