Originally posted by dlh There've been a couple of occasions when I've mentioned the fact that the lens I've got will "auto-extend" or "auto-retract" by means of gravity if I don't hold it horizontally.
Yes, it does that. I never point it so vertical that it matters, but I can see it would be a problem if shooting steeply upward. I wouldn't say the lens is loose, just that there is a lot of weight in it, so it sags as you say. My only criticism of the DFA 150-450 is that the focus lock can only be engaged at 150mm; if you could use it at any focal length, your problem would be solved.
