Posted this on another forum so I though I might share here (probably more appropriate).
Modified Tair 3 to electronic shutter release.
Taking it apart.
Taking apat of the trigger assembly.
Attaching 3 pin switch (two roll pins and a screw). When the rigger is pulled, it will push the switch lever, activating it.
Took apart electronic shutter cable release and used it for this project. Solder and insulated connections. Also added several springs around first pin for little bit more resistance.
All done, very secure and works like its suppose to, electronically now.
And a few of the lens (s).
Few others (two are MC versions).
