Show Printable Version 3394 Likes Search this Thread
04-13-2015, 01:29 PM   #2671
yasik, why did you have such a high rate of misfocused images ?
04-14-2015, 05:43 AM   #2672
QuoteOriginally posted by Stagnant Quote
It seems like, there was to many internal reflections, from the exposed sensor when wideopen, because from the point of eyeviewer and focus indicator there should be more. Or maybe I should check my eyes
04-14-2015, 03:22 PM   #2673
QuoteOriginally posted by yasik Quote
I normally use live view with magnification and focus peaking, when shooting manual lenses. Can be quite hard, especially with longer lenses, but I manage to nail focus with a 135 mm lens that way at f 3,5 . My eyes are not good enough to see all the details in the viewfinder and the implementation of focus confirmation is not precise enough for my taste.
04-15-2015, 04:29 PM   #2674
scratchpaddy's Avatar
I agree with the others, a fine image, yasik!
This lens has a very abrupt transition from in- to out-of-focus, even when stopped down some, which compounds the difficulty of the shallow depth-of-field. Other lenses are more forgiving of a slight mis-focus, but with the Helios 40, it's either perfectly in focus, or obviously blurry. The lens makes you feel like you missed a lot worse than you really did.
04-15-2015, 04:56 PM   #2675
paulh's Avatar
A couple more with the Zenitar 16:
04-16-2015, 07:51 PM - 3 Likes   #2676
fiveseven's Avatar
Few of Jupiter 9's
The latest one... Made in 1954, M42 so it's possible a conversion from Zenit SLR or RF version. What's interesting is that the yellow or gold coating is what Soviets used in the 70's and 80's, most if not all early Soviet lenses usually had blue coating.
Very clean and smooth operating lens.
04-18-2015, 05:54 AM   #2677
Andrew_Oid's Avatar
A photo taken this morning with the Helios 44-6 at f5.6 of a freighter unloading lumber onto tenders on the Chao Phya River in Bangkok.
DSLR-A850  Photo
04-18-2015, 06:07 AM   #2678
Andrew_Oid's Avatar
Helios 44-6 at f2
Here's another photo taken with the lens at f2, adjusted for contrast and brightness.
DSLR-A850  Photo
04-20-2015, 06:31 PM - 2 Likes   #2679
fiveseven's Avatar
Self made lens from rare Russian movie projector.... 130mm, full working aperture.
04-20-2015, 06:37 PM   #2680
Jorgario's Avatar
QuoteOriginally posted by fiveseven Quote
Nice pictures, I really liked number #3 (without counting the lens ones) ... and your projector lens has the Hellios 44K-4 as a base, and some filters and a hood, and some extensions that convert the 58 mm focal length into a 130 mm lens ? Is that right ?
04-20-2015, 10:16 PM   #2681
fiveseven's Avatar
Thanks.
The base (focusing) body is Helios 44M (M42). The filters and spacers were made to fit around the lens itself not to provide any optical distance.
The focal length of the lens is 130mm and has a long sensor register working distance so I used M42 extension rings on the back of Helios body to create proper working focusing distance.
04-21-2015, 07:58 AM   #2682
Jorgario's Avatar
I tought the Hellios 44M has a focal distance of 58 mm !!
04-21-2015, 08:42 AM   #2683
fiveseven's Avatar
Helios 44 and pretty much all Soviet SLR lenses are about 45mm sensor register distance.
True, Helios 44M has 58mm focal length, this conversion only barrows Helios body, all the Helios glass elements are gone and are not there. Projector lens is inside instead.
04-22-2015, 01:05 PM - 1 Like   #2684
Jean Poitiers's Avatar
Hey, nice and I have done that, too ... see https://www.pentaxforums.com/forums/122-lens-clubs/264161-projector-lens-club.html
04-23-2015, 06:26 AM   #2685
fiveseven's Avatar
Nice, it has working aperture as well?
On mine I still shoot mainly open, steping down would would probably be good as a macro lens as it's much sharper than most if not all telephoto's I've tried.
44k-4, a7, adapter, aperture, camera, era, f/2.8, flare, flektogon, helios, helios 44k-4, ideas, industar, kmz, lens, lenses, ltm, mir-1, pentax lens, photos, picture, pm, poles, post, russian, sydney, thanks, zeiss, zenitar
Pentax Lenses on FF Club pinholecam Lens Clubs 1015 11-09-2023 05:59 AM
Soviet Lens Club - MIR lens stevewig Lens Clubs 4 03-25-2016 02:50 AM
K-mount soviet lenses database. micromacro Pentax SLR Lens Discussion 39 01-21-2014 11:53 AM
All times are GMT -7. The time now is 03:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
