Originally posted by Dartmoor Dave I've been doing a bit of reading, and the depressing (and to me shocking) answer is that, yes, they do. Apparently all Nikon low-end consumer cameras use lossy raw compression, while Canon uses lossless. And of particular relevance to the discussion above on this page is the news that all Sony cameras use lossy compression, even top-of-the-range ones. Inevitably, Pentax isn't mentioned in the article linked to below, but based on my experience with the K-S1 I'd be willing to bet that it uses lossy raw compression. And I'd also bet that the K10D doesn't.
I think some more research is needed to try to find out which Pentax cameras use which sort of raw compression.
Compressed vs Uncompressed vs Lossless Compressed RAW Options Thanks for that link, Dave. I had a read of that article and, while some cameras allow you to specify different types of RAW compression, I have not seen such an option on either my K10D or K-3.
However, I recall noticing some years back that on the K10D there was a size difference between PEF and DNG. We Pentax owners are fortunate that we can choose either RAW format. Many other brands do not provide that option.
So, I decided to do a test and the results astounded me. I just stood at my front door and took two shots in fairly quick succession changing the RAW file format between shots. And then I did the same with my K-3.
K10D, 3872X2592, 10 MP DNG = 16.1 MB PEF = 8.78 MB Less than 10MP?? Compressed? Yes, I think so.
K-3, 4016X4000 24.1 MP DNG = 31.4 MB PEF = 31.0 MB
I don't know what to make of those numbers. Would anybody care to try to make some sense of it? Just how raw is the PEF on the K10D? Could others please do a similar test to see if you get numbers close to mine?
