Hello again, everyone.
I finally did a thorough lens test of my three Takumars at the same time, with the same subject and at the same aperture.
I'll post some of those shots later, but for now, here is a comparison between two lens I like very much, but had never put through their paces equally.
I'm referring to my K55mm 1.8, and my Takumar 55mm 2.2.
In past tests, which were not that thorough, it always seemed that the K lens was noticeably sharper than the Tak, while the Tak had more pleasing colors.
Now, I'd like to show you all the results.
Photo #1 This is the Takumar K55mm 2.2 @ f8.0
Photo # 2 is the K 55mm 1.8 @ f8.0
Both photos were taken minutes apart. Only the time needed to carefully remove the Takumar and the M42 adapter ring, and mount the K55 with the camera on a tripod elapsed between the two exposures.
The only alteration done in Lightroom was to increase the whites by +20 to both photos, and to decrease the exposure on the K55 exposure by .26. This was done, because in other tests the K lens always seems to produce a slightly brighter image when compared with the Tak.
I believe I focused as carefully as I could.
I think the Tak is sharper, and yields a more pleasing image. It is, however, a slower lens to focus.
I would appreciate your opinions and observations.
Thanks,
Mike
