Originally posted by johnc Jos - With pop up flash? Well done! Did you use anything to diffuse or reflect it?
I guess using the pop-up is maybe an advantage of the 50mm (and DA 35mm limited macro?). Im guessing that the bigger macro lenses can possibly block out the pop up flash at close quarters.
John
A snoot brings the light from the pop-up flash over the lens to the subject.
The snoot ends with a diffuser 9 x 8cm.
I use more snoots adapted to the lenght of the lens combination.
The shorter snoots have for diffuser a double layer of polystrene foam, the longer snoots a single layer.
Gr. Jos
