Originally posted by Jens Lyn IV Those metadata don't make a lot of sense; my K-1 certainly doesn't pretend my Irix is a Sigma zoom lens. I'm curious how this could have happened.
And if the edges are that bad on APS-C, you are right to demand a replacement, and the shop are full of BS blaming it on the lens mount. My copy looks impeccable on full frame, even with pixel shift enabled and the sensor shifted ouside the nominal image circle. Ideally you'd test the replacement with a full frame camera, but at least use Composition Adjustment to get as far into the corners as possible.
Good luck.
Sorry about that, first image was from my old Sigma 17-50 at 17mm, (now corrected) closest I could get to 15mm, I did a side by side test to confirm in the field what I already knew regarding the lens mount, before I sent the Irix back.....yes BS, I understand them checking to see if the lens has a problem, and they are going to check the next lens before they send it to me. Like you I got annoyed when they immediately blamed the lens mount!
I do now have an email from them confirming they will refund if I’m not happy, apparently they are not aware of the QC problem, I shouldn’t believe everything I read… and they will look at it next week…I suspect the first copy was a returned lens and the replacement delay is due to a lack of Pentax fit stock …..Always a problem with Pentax fit lenses here.
Thanks again for your input…..
