03-30-2016, 11:53 AM - 9 Likes   #2566
simon_199's Avatar
A couple of interior shots with the DA 10-17
03-30-2016, 02:39 PM   #2567
WPRESTO's Avatar
QuoteOriginally posted by simon_199 Quote
Residenz, Munich, been there, photographed at least the Roman emperors hall. The continental aristocracy really knew how to do a ceiling.
04-01-2016, 10:34 AM - 4 Likes   #2568
simon_199's Avatar
QuoteOriginally posted by WPRESTO Quote
Yes, that's the place, some halls were really pretty impressive in size.
This is the Olympic stadium built in '72, with (not so) Fishy eyes as always
04-01-2016, 04:19 PM - 1 Like   #2569
Grippy's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
04-02-2016, 04:01 AM   #2570
WPRESTO's Avatar
M and I were in Munich some weeks before the start of the '72 Olympics, traveling for research purposes, visiting museums. Did not see that stadium, but did get sight of and a picture* of the Olympic spire that was erected from one of the towers of the Frauenkirche. Think I scanned that chrome and posted some long time back. We moved on the Graz and Vienna well before the Olympics started.
*Pentax Spotmatic (1st version) with 50mm f1.4 Takumar.
04-08-2016, 03:29 PM - 3 Likes   #2571
WPRESTO's Avatar
Bower 8mm. As much distortion removed as LR would allow.
04-10-2016, 11:22 AM   #2572
Otis Memorial Pentaxian
QuoteOriginally posted by ThorSanchez Quote
My first attempts at shooting the night sky, with the Rokinon 8mm fisheye on the K-3ii.
Yikes! Someone shrunk Orion!
04-10-2016, 11:25 AM   #2573
Jaguar. Sorry if I already posted another image similar to this one.
My dad had one of these (Jag XK 120). Seeing your photo brought a grin to my face. Thanks for sharing.
04-10-2016, 02:49 PM   #2574
You mean keeping the tree entirely in the picture or there any hard limit?
04-10-2016, 04:33 PM   #2575
WPRESTO's Avatar
QuoteOriginally posted by Nicolas06 Quote
When the LR "distortion" slider is moved off center, it causes either barrel or pincushion distortion. To eliminate FE distortion, of course you move it to cause pincushion. When you crop to eliminate the lost areas, it is entirely the corners. The center left-right and center top-bottom of the image are preserved.Maybe I can post three images to demonstrate.
Below:
1) the first image has no distortion removed, but I've opened the shadows some and tweaked the colors to my taste;
2) the second image is the maximum pincushion distortion that the LR slider can apply
3) the third image is a crop of the second.
Differences are subtle. A telephone pole at left still leans, but it isn't as curved as in the original. More iteresting a valuable, the beautiful tree at left is now wider than in the original. The corners that have been lost do not contain visual information that contributes significantly to the image.
04-10-2016, 04:54 PM   #2576
I ask because by default when I look at my 10-17 pictures, even at 10mm in DxO, they look perfectly rectilinear as DxO apply a lens profile to it automatically and it tend to change a bit the aspect ratio. Honestly, not much is lost except the corners.
I can use a slider to check how much correction I want from perfectly fish to perfectly linear. If a lens has no profile, I can correct manually barrel or pincushion, but it doesn't work that well if I try with the 10-17. I have to choose the "fisheye mode" and then it become easy, even manually.
Of course as I am not necessarily interrested, I tend to disable the correction, and I try to have the right level of fish directly from setting the right focal length with the 10-17.
04-10-2016, 05:00 PM   #2577
I does something like that to your last image... But it may not look better if your go 100% defished...
And if I combine with "volume" sliders I can get the second one.
But then I don't think the picture would have this place in this thead and your version look more pleasing than fully correcting the picture.
04-10-2016, 07:05 PM   #2578
Below:
I generally don't use Lightroom for defishing (if/when it makes sense to do so). The "distortion" is not classic barrel and the sliders often provide a less than satisfying result. I prefer PTLens for the task since it has algorithms specific to setting a fisheye image straight.
04-11-2016, 02:28 AM - 5 Likes   #2579
Grippy's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
04-14-2016, 02:51 PM - 5 Likes   #2580
The 10-17 at 10mm, just mildly cropped, no distortion correction applied, processed with Nik Silver Efex for drama. This is such a fun little lens!
8mm, attack, bit, bowl, camera, comp, dslr, elpolodiablo, fisheye, fisheye fever club, flash, flickr, hugin, images, k-3, lens, lenses, list, night, pentax, pentax lens, pm, post, rokinon, rokinon 8mm, sensor, shark, shutter, steve
Share your shots with the 03 Fisheye NeilGratton Pentax Q 157 12-28-2015 01:23 AM
Software to un-fisheye the fisheye? ChopperCharles Pentax Q 5 06-08-2013 01:25 PM
Do you use your fisheye? pentaxian_tmb Pentax SLR Lens Discussion 53 02-25-2013 03:41 PM
Inexpensive fisheye and semi-fisheye adapters? billiam Pentax Camera and Field Accessories 8 11-09-2010 02:08 PM
what lens for fisheye fever kjacks Pentax SLR Lens Discussion 27 05-21-2010 07:51 AM
All times are GMT -7. The time now is 04:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
