Originally posted by harmonica2 Still experimenting with this "subject." I agree that purple fringing is a big problem with this the DA 10-17 FE. I use Aperture, and I have yet to find an easy way to remove it using that software.
You have a number of ways :
1. Sometimes a simple auto-curves will cure your ills.
2. A3 has special tools for wiping away PF - use the CA block.
3. If no other purple in the image then you can selectively desaturate colours.
4. Halo reduction sometimes works.
5. Lens Correction profiles can also do the job.
6. PTLens (small $) works too.
See which works for you.
