Thanks, Barondla, appreciate it!
What I find amazing about whatever LB I use, experimenting is part of the joy of owning one. Confession - I don't have enough patience with PS3, specially for creation of special effects in post processing. And with LB, I have what I need/want/crave to get that "look" I envisioned. So I play around with them quite a bit at little or no cost.
Plastic bag - really just a cheap sandwich bag (both layers) stretched over the hood of the lens, holding it in place is a rubber band. I like the moody look with it, I think it acquires the soft focus and muted detail as Plastic optic, but with out that dreamy look that Plastic optics gives.
Another recent little experiment - $1.00 37mm UV filters... I simply remove the glass, cut plastic circles to size (from old CD cases), than use various grit sand paper on plastic, until I "think" I have the effect I wanted. I'll get some daylight later in the week, will post...
Mike - you really cracking me up!!! And
"...trying desperately to not order some stuff from Lens Baby..." Yeah, good luck with that! What's on the list?
BTW, that old, cheap x2 TC is Sears, bought it here, on the forum for next to nothing, and whatever optical formula it uses, I really like how it works with Composer, I find little to no loss in image quality. Wide open with Sears TC:
Regards,
D
