Interesting shot Nesster! Like the bright colors. Creative subject. Now I understand the tin foil part. Remember reading about that trick with older lenses. Don't remember what it does exactly.
Mike, doubt that the 2.0 mount would fit on the Composer for various reasons. Comparing my LBO to Composer:
1. Composer base is about 25% bigger diameter. All newer LB are larger - think its because of the optic swap system.
2. Unlike older LB bases the Composer base has sides (pointed toward front of lens. This houses the tension ring and "ball" of the Composer.
Might be able to buy a Composer and grind bayonet away then mound back of screw thread lens to it. This would move infinity focus point. Not a problem on LB - theres enough wiggle room.
Craig Strong (LB creator) might be able to whip up Screw mount. They seem to have dropped all non af mounts from their offerings. A shame that. You would love a Composer!
Mike, wonderful flower closeup. So soft. You know its at the limit when you have to stretch the LB. Composer won't allow that! It maxs out at about 18". Use the closeup lenses a lot with it.
thanks
barondla
Check out POINT & SHOOT CONTEST #17 WINNERS in P&S forum. Enter #18. Any brand camera. Enter now!
