Here's the Mirex adapter; I don't have a K-1 (quite) yet so just the gear shots for now, with a K-5 standing in for the K-1:
Lens-facing side on left. The spring puzzled me for a bit; it's to catch the diaphragm actuator and stop down the lens (unlike with K-mount lenses, the Pentax 645 actuator defaults to open). The bronze-colored flange at left is the lens release lever.
Camera-facing side on right. The shift mechanism is at top; press on the lever and slide the lens or camera to the side. The toothed flanges on either side are for rotating the lens to change the tilt and shift axes. They are a challenge to operate when the adapter is on the camera and a lens is attached.
Side view showing the tilt dovetail mechanism. On the other side there's a set screw to lock down the tilt, and another screw for setting the tension. The set screw gets in the way of rotating the adapter (it can hit the grip and/or the flash/prism hump, depending on the camera) so it's good there's the tension adjustment; you don't really need the set screw. Note the tripod foot, with Arca/Swiss-compatible dovetail.
FA 75 adapted to the K-5, fully tilted (top) and fully tilted and shifted (bottom)
