Here are a few shots taken with my Sears f/4 80-200mm zoom with my Pentax K110D dslr. I shoot film, too, but using the dslr does give online-postable results much more quickly.
Complete lens inscriptions:
Auto Zoom Sears Multi-coated 1:4.0 f=80-200mm (/)55 No.967557 | 202-737020 Korea
The lens is a K-mount without the "A" setting. F-tops 4 to 22. It's a one-touch zoom, meaning the main front collar handles both Zoom and Focus, and will creep forward if you lean forward with your hand off of it. When the ring between the aperture ring and the focus-zoom collar is twisted about 165-degrees, the "Macro" close-focusing function is accessed, according to the labels on the scale revealed, offering reproduction ratios between 1:5 and 1:16, depending on how the focus/zoom ring is adjusted.
Still-life, Not at maximum magnification. ISO 200-400, using K110's pop-up flash with something like f/8:
Silhouettes and shadows on widow shade. F4, ISO 200-400:
Backlit goat portrait. F4, IS0 800, 1/3000-4000. When I went outdoors, I opened the aperture and turned up the ISO to get high shutter speeds--it was breezy, critters move, and the K110 has no shake reduction:
Oscar the Donkey. (The Goat's name is Oregano) Similar specs, unless the shutter was a little slower, due to some shadows falling around Oscar and the side of the barn behind him:
First sky shot, I set the aperture wide open to set the exposure with the "AE-L" button, then unbeknownst to the K110 I stopped down to 5.6 to deepen the sky a tad:
Ford tractor shapes:
Power lines. Another shot with a lot of sky, so I believe I stopped down one setting from wide open:
Stubblefield. This one is shot wide open, focused on that rim of higher ground about a third back. It's funny, I shot the same scene at f22--what I would normally do with a landscape--but for some reason this one looks much better than the one that's sharper all over:
Well, these are mere snapshots compared to most of what is getting posted in this thread -- witness Dewman's recent geese on amazing waters! I'm not sure I have actually taken pictures with this lens before these test shots, due to my dislike of one-touch zooms. So far I am finding too much about it I like, so I'll have to keep it.
