08-14-2019, 09:26 PM   #91
QuoteOriginally posted by K1N8 Quote
Hmmm, I have a Mamiya Sekor C 80mm /1.9 for 645 and there are adapters to PK. Would that work with a K-1? Covers the full frame? What focal length would that translate to?
Your Maniya 80mm C series will cover the full frame. Adapters are slightly more than they are for aps-c to 35mm full frame remounting. Imported, they are inexpensive. You lose electrical contacts and have to meter in the green mode. Look up some of Northrup's detailed expository photo technology teaching on You Tube to figure focal length. From the hip, I think it stays 80mm, but could be slightly longer. I don' really know.
08-14-2019, 10:42 PM   #92
swanlefitte's Avatar
A lens mm is defined by the distance from the lens to the focal plane at infinity. A lens with multiple groups can have it's theoretical center at any place so the lens size won't actually be that many mms long. A telephoto has a rear element that makes the focus closer than the mm distance. Most 500mm lenses are telephoto because 500mm long lenses are unweildy, put a telephoto element on and it can be 200mm in actual size because this changes the theoretical center of the "lens" which is many lenses combined such as a lens with 8 elements in 5 groups. The center isn't from the front element but where the center of these groups affecting each other is. That can end up being in front or behind all the lenses or somewhere between.
No matter what you focus on, be it a 8x10 film or a 2mm micro film a 50mm lens needs to be 50mm from it's center to the focal plane at infinity.
08-18-2019, 02:47 AM - 1 Like   #93
amateur dirt farmer
pepperberry farm's Avatar
K-5 IIs with Mamiya Sekor 35mm f2.8
and back to the point of this thread:
08-18-2019, 02:48 AM - 2 Likes   #94
amateur dirt farmer
09-06-2019, 07:44 PM - 1 Like   #95
amateur dirt farmer
K-5 IIs with Mamiya Macro Sekor 60mm f2.8
09-26-2019, 04:59 PM - 2 Likes   #96
ivanvernon's Avatar
A soft focus approach
Here are a couple of soft focus shots with the K-1 and Mamiya 645 C 145mm f 4.0 soft focus, I believe one of the best soft focus lenses out there.
PENTAX K-1  Photo
PENTAX K-1  Photo
10-13-2019, 05:34 AM - 1 Like   #97
ivanvernon's Avatar
Adapter for medium format Mamiya lenses
I have seen adapters to use Mamiya medium format lenses on K-mount cameras listed on eBay by Kippon and Fotodiox. These two adapters both appear to be of good quality, well machined, etc. I have the Fotodiox adapter, and photos of this adapter are attached. Prices on the Fotodiox adapters seem to be significantly lower than for the Kippon adapters. Why I cannot say. Both adapters seem to perform identically in fitting medium format M645 Mamiya lenses to Pentax K-mount cameras. With either adapter, the camera can be used in only Manual or Aperture Priority modes because neither adapter provides the electronic connection to the camera that would be needed for other modes.
There are fairly complete lines of M645 lenses in both the original C configuration as well as the N configuration. These lenses tend to be quite similar except for improved coatings on the N line. Both the C and N lenses tend to be very well built with all-metal construction, and generally lighter and more compact than their Pentax 645 counterparts. They are pleasing to use from a tactile standpoint, and I have found them easy to focus, though the focussing rings turn opposite from the Pentax direction. With Mamiya, your turn the ring to the left for infinity and to the right for closeup shots. Prices tend to be quite competitive, particularly for the C line, and I have found no problems with flare with the C coatings. For the same price, of course, the N line is to be preferred.
I have acquired nine of these lenses--including 45mm, 55mm, 70mm LS, 80mm.1.9, 80mm macro, 145mm soft focus, 150mm, 210mm, and 300mm. Generally speaking, these lenses tend to be a little lower in price than the A version of the Pentax medium format lenses and sometimes one stop slower than their Pentax counterparts, which may be why they can be produced in lighter and less bulky configurations than the Pentax lenses. Mostly these lenses offer no particular advantages over their Pentax counterparts although there are a few standouts. I particularly like the uber-fast Mamiya 645 C 80mm f 1.9, said to be the fastest medium format lens ever produced. The 145mm soft focus lens is the best soft focus lens I have ever used; though the soft focus lenses are no longer much in vogue I still like playing around with them. At the long end, the 150mm and the 210mm are quite sharp and offer a lot of reach for the money for K-1, K-3 cameras. There are some super long lenses (500mm) as well as several zooms that I have not tried and cannot comment upon.
Overall, this exercise in adapting Mamiya medium format lenses to the K-mount cameras has not produced any startling results, though you certainly can get some quality glass for low prices. Corner performance should be excellent since on K-mount cameras you are using the sweetest part of the image circle. I should point out in closing that it is not possible to adapt these lenses to the Pentax 645 line of cameras owing to incompatible registry distances which would necessitate including corrective glass in the adapter, and so far as I am aware no such adapter has been built.
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
10-13-2019, 05:47 AM   #98
QuoteOriginally posted by ivanvernon Quote
That's quite the collection. Even if there isn't really an advantage in quality, i do like the certain "charm" in the results. I only have the 80mm f1.9 though.
10-13-2019, 06:33 AM - 1 Like   #99
ivanvernon's Avatar
That's true. As a retiree, it at least gives me something to do! I sometimes get out the same focal length in Mamiya C, P645, and P67 to try them on the same subject for the sake of comparison. The results are inconclusive.
10-14-2019, 01:22 PM - 4 Likes   #100
ivanvernon's Avatar
Some flower shots with Mamiya
Here are a few shot with the K-1 and the Mamiya 645 C80mm f 4.0 macro (medium format lens).
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
10-28-2019, 03:55 PM - 3 Likes   #101
ivanvernon's Avatar
Test shots with Mamiya 120mm
Here are a few garden shots with a relatively newly acquired macro lens, the Mamiya 120mm f 4.0 macro 1:1, sometimes referred to as the poor man's Zeiss 100mm f 2.0 macro 1:2, and I do not disagree. This is a medium format len, so you are using the sweetest center of the lens on K-1 full frame. The Mamiya requires an adapter and is not as fast as the Zeiss, but goes to 1:1 without any extension tubes or other "appliances." Image quality is excellent at about 1/4 of the price of the Zeiss. It is also an excellent and sharp lens for general photography in portraiture or landscape.
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
10-28-2019, 04:57 PM   #102
QuoteOriginally posted by pepperberry farm Quote
Very nice Indeed
10-28-2019, 05:09 PM   #103
amateur dirt farmer
QuoteOriginally posted by niceshot Quote
Very nice Indeed
thank you...
10-29-2019, 07:14 AM - 3 Likes   #104
ivanvernon's Avatar
Medium format lens, Mamiya 645 C 45mm f 2.8.
Introducing the Mamiya 645 C 45mm f 2.8, said by some reviewers to be the sharpest of the Mamiya 645 C line of lenses.
PENTAX K-1  Photo
PENTAX K-1  Photo
11-01-2019, 10:07 AM   #105
Nice! How does it compare to the Pentax 645 120mm Macro?
6x7, bayonet, camera, cameras, cs, details, farm, flickr, iso, k-mount, lens, lenses, m42, mamiya, mamiya lens, mamiya sekor, mamiya sekor 35mm, pentax lens, sekor, shots, slr lens, test, tomioka, tripod
Which lens adapter for Mamiya 646 and Pentax 6x7 lens popkrab Pentax Medium Format 2 02-21-2012 09:11 AM
mamiya/sekor21mmf4. sx lens modification bobwells Troubleshooting and Beginner Help 3 04-24-2011 12:08 PM
DIY Mamiya-Sekor M645-to-PK lens adapter pacerr Pentax SLR Lens Discussion 11 04-10-2010 06:28 AM
All times are GMT -7. The time now is 11:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
