Originally posted by barondla
Yes this lens is a C mount. It came out of a security camera. You will need a mirrorless to make it focus anywhere near infinity, I use it full frame on a Pentax Q7 and as a circular fisheye on the Olympus EL-P1 m4/3. Have also seen it used on Sony. It is such a cool looking lens and performs very well. It actually has a few feet wider field of view than the real Pentax Q fisheye. The Q will even take 8mm D lenses with slight vignetting.
Looked at your projector lens club and will try some shots . Have a Kodak zoom and a Leica prime to try.
thanks,
barondla
If I may stray off the thread topic, a bit...(sorry Jean!)
Something I've come across that this lens would probably work well for is a
fisheye macro relay lens. This version is by John Hallmen. It involves using a reversed wide angle lens and extension tubes between the fisheye security camera lens and the camera body. The image in the viewfinder is dark and inverted, but the intervening optics and tubes allow the lens to cover at least APS-C frame size. More details of Hallmen's approach here:
DIY ? Macro fisheye | Oryctes nasicornis, European rhinocero? | Flickr
I'd really like to try this technique myself; I've got just about everything I would need
except the fisheye optic. They're not expensive either. Just haven't got to it!
---------- Post added 01-08-20 at 11:44 PM ----------
Originally posted by UncleVanya
But it is interesting to see what can be done with the larger sensor with these tiny lenses. I wonder if reversed they might make good macro shooters.
(Getting back on subject...) I'm curious to see how these 110 lenses perform in reverse for macro shooting, too. Reverse stacking on longer lenses might produce interesting results as well. Looking forward to what you do with them.
