Originally posted by edom31 This little fellah came in today. The tab is an issue... Can only shoot wide open now as the pin does not engage unless using a flanged adapter.
I have the same Fuji macro lens.
I find it elegant and very well made.
Mine came with the original extension tube like yours.
Got it for cheap cause it had damaged/bent filter attachment.
I bent the rim, filed the tab, and pronto... it was a perfectly usable lens.
The tab is very easy to remove. I used a simple hand file cause the material is soft enough.
This lens, like practically all other 50/55/60mm vintage macro lenses, still performs at top level even on high-res modern sensors.
Well worth putting it to actual use. I regret not having used it enough, but I have many other similar optics, and for ease of use I tend to prefer PK lenses over M42 ones.
Adapted on non-Pentax bodies it wouldn't make any difference. I have a new stabilised Panasonic m4/3 body that could be the perfect camera to use this macro at its best...
Cheers
Paolo
