Originally posted by Wheatfield Lovely stuff still being posted here. John how are you doing those bokeh panos? If you don't mind giving away your secrets, that is.
No problem! I guess this is a variation on what’s sometimes called the Brenizer method, or bokeh pano. Basically I simply do a series of shots wide open using a telephoto lens to cover a scene that is normally shot more widely, then stitch the shots (in my case, usually using Lightroom).
These two are vertical panos made of three frames each, shot wide open with the 85mm (horizontal or even larger panos work as well). As with all bokeh photos you need to find scenes with some meaningful depth and choose a single focal point. Don’t change the focus in between the shots (I use back button focus to avoid this happening but manual focus would do).
I have also shot these pics as HDR too just owing to the dynamic range needed, so each image is actually 9 frames (3 pano x 3 exposure brackets). Lightroom does HDR panos in one step but a HDR then stitching workflow would work too.
Finally these shots have been toned, I’ve used LUTs to alter the colours, and finished with usual processing. Processing for me is 90% lightroom with sometimes a trip to photoshop for some colour management (often Orton processing), and sometimes colour fx or luminar for a little more pop .....depending on the look I’m going for). The colour is the most challenging bit (that I’d like to get better at!).
Give me a shout if any bits need more explanation, there’s no secrets here! It’s worth saying that a very similar result can be often obtained in a single shot with the 85mm, these images are not that much wider.
John
