I'm still exploring this lens to get the most out of it.
And here's another nice surprise!
As you can read
here the DFA21Ltd is
compatible to the Pentax DA TC1.4x. You get a
Pentax DFA f3.5/29.4. Since the TC doesn't change the minimum focusing distance this combo also has 18cm minimum focusing distance!
You may think that I'm nuts to use an ultrawide with a TC. But let's see ...
Let's have a look at some images to show the vignetting of the combo, made in
K-1 FF mode at
near infinity - overcast sky:
K-1 | Pentax DFA f3.5/29.4 | FF mode | 29.4mm | f3.5
K-1 | Pentax DFA f3.5/29.4 | FF mode | 29.4mm | f4.0
K-1 | Pentax DFA f3.5/29.4 | FF mode | 29.4mm | f5.6
K-1 | Pentax DFA f3.5/29.4 | FF mode | 29.4mm | f8.0
K-1 | Pentax DFA f3.5/29.4 | FF mode | 29.4mm | f11.0
Now - that doesn't look too bad, I think. Indeed much better than DA TC1.4x with DFA100WR!
Here's another example with subject at short distance ...
K-1 | Pentax DFA f3.5/29.4 | FF mode | 29.4mm | ISO100 | f3.5 | 1/30s
I'm pretty sure that if I cut an opal pane for this lens and create
flat field correction profiles (=> called in RawTherapee) for each aperture and apply these to the raw files, this vignetting will vanish fully. In Capture One Pro this is called
lens color calibration (LCC) profile.
Everybody may judge by herself / himself if such results are usable. I think they are.
Now, that's on 35mm fullframe. If you use an
APS-C camera you get the
field of view of an ~f3.5/45mm lens - normal field of view with 18cm minimal focusing distance and astonishing bokeh! Do you know any other normal lens that does offer this apart from 50mm macro lenses?
Some more notes:
- such a combo
is not possible using the DA21Ltd because this APS-C lens is not compatible to the DA TC1.4x
- the DATC1.4x/DFA21Ltd. combo shows roughly the size of the DFA28-105
- the DATC1.4x/DFA21Ltd. combo is slightly faster than the DFA28-105 @ 45mm which is f4.0
I think this is something that should be considered and mentioned when it comes to describing the DFA21Ltd. - another argument to justify paying the price - maybe?!
