When I took the rubber grip off, there were no screws of any kind in the area then revealed. After taking the tape off there were 4 (or was it 3) that could be seen. After sliding off the metal sleeve the tape also secured, two more screws could be seen when zoomed to a particular position..
The ones under the tape, may have only served to hold the front molding of the zoom slider on. The later two seemed to be holding metal pegs that slid in notches (or allowed notches to slide around them). The surfaces I could see at this level of disassembly didn't seem to be binding against each other, for if they had they would have also made focusing bind, which is as free as anyone could want. I think whatever suffers from dried lube, or is binding for some other reason, or is jamming must be deeper in the machinery.
Here's a little sample picture. New tulip tree leaves on an overcast morning. Wide open at f3.8, setting on 24mm (equiv to 35 on my K110D):
Some other test shots of flowers I tried this morning had me wishing that the closest focus distance was closer, the "Macro" capability not available at the part of the zoom range I can access. I wonder what difference a single +1 diopter supplementary lens would make. Of course stopping down (in brighter circumstances) could throw more foreground into focus.
