07-15-2016, 01:25 PM   #22516
QuoteOriginally posted by gaweidert Quote
I did a lot of pondering over whether to get a Kirk or Eckla window mount. I finally went Kirk because how deep the doors on my Ford Edge are, i was not sure if it could mount properly. In any event, the Kirk works fine for now. I did have to get a couple of 1" risers so I could get a full rotation of my gimbal heads
Because car door windows are usualy slightly curved I use a couple of wooden wedges to get the Kirk window mount to fit properly
07-15-2016, 03:13 PM   #22517
Weevil's Avatar
QuoteOriginally posted by Ducatigaz Quote
A new car window mount arrived this afternoon, this should help me overcome the problem of lack of height of the door glass because the platform that the ballhead is mounted to can be lowered, also the ballhead can be moved back or forward. It's made by a company called Eckla I have test fitted it to the door and it looks like it will work. The new car we are getting has more rake on the windscreen so the 600mm will not go through the drivers/passenger windows on the Kirk window mount
nice, what kind of car is this ?
I was thinking of a windows mount for a while for the 250-600, but did not pull the trigger yet... I saw those Eckla mounts, and the reviews were pretty good.
I have a Nissan Murano, I don't know which would be the best for my car... but the Eckla is interesting!
Show us some pics with the lens mounted!
---------- Post added 2016-07-15 at 18:20 ----------
QuoteOriginally posted by Racer X 69 Quote
Sigma 300mm f2.8 APO EX DG.
Thanks! yes I forgot that one, actually, we dont see pics taken with this one often here...
I used to see a brand new copy sold from a online store in AB for 2000$ CAN 2 years ago...
I think that was a very good price!
07-15-2016, 08:26 PM   #22518
rvannatta's Avatar
my solution: a used pentax f* or FA 300 f 4.5 and the new pentax 1.4x converter.
07-15-2016, 09:46 PM   #22519
Weevil's Avatar
QuoteOriginally posted by rvannatta Quote
OK, but it is not FF compatible...
07-15-2016, 10:03 PM - 9 Likes   #22520
Here are some shots with my old manual lens SMC 500mm f/4.5
Some more pics with my SMC A 400mm f/5.6
07-15-2016, 10:47 PM   #22521
rvannatta's Avatar
QuoteOriginally posted by Weevil Quote
indeed the converter isn't FF which is a problem. it has everything to do with why I took my ancient Pentax - A 400 f-2.8, and equallly old pentax -L converters to alaska recently. I am most hopeful
that Pentax will soon bless us with an FF converter although manual focus isn't all bad in bird photography. I don't know how many times i've taken a picture of a fairly 'small in the frame' bird
and had the auto focus --focus perfecty on the background, and put the bird completely out of focus.
07-16-2016, 12:16 AM   #22522
Canada_Rockies's Avatar
M 400/5.6 is working for me
Here is a recent shot taken with the M 400/5.6 on K-3 1/125" @ f/8, ISO 800. It's a decent shot. This is the full 6000x4000 image. Taken on Manfrotto 055B with the LensMaster RH-2 gimbal head. Loving it! I should have switched from the ball head years ago. Without the AFA 1.7X the green button gives me a good exposure without compensation.
07-16-2016, 12:20 AM   #22523
Man With A Camera
Racer X 69's Avatar
But the Sigma is. As well as the Sigma 1.4 and 2.0 converters.
And they work great.
07-16-2016, 04:50 AM   #22524
Here are some pics with the 600mm mounted. The Kirk window mount sits on top of the door trim so with a ballhead fitted it is much higher. The platform on the Eckla mount can be lowered so the ballhead is below the top of the door trim. In one of the pictures you can see that I have riveted a piece of aluminium to the bracket that should slide down past the window and into the door, the bracket supplied was not long enough to be safe, I didn't want the whole lot falling off the door when I'm driving up a track. With the platform fully lowered I think a gimbal could be used and I will give this a try at some point.
The measurment of the window opening at the back of the door on the peugeot 308SW is about seventeen inches, on the new car that is coming, a Vauxhall Insignia Sports Tourer the window measures about fourteen inches.
07-16-2016, 05:29 AM   #22525
RockvilleBob's Avatar
nice set up for your car. Does it accommodate a BetterBeamer?
07-16-2016, 05:32 AM   #22526
QuoteOriginally posted by RockvilleBob Quote
the mount can be turned round so that it's on the outside of the door then a flash braket can be used.
The Best Window Mount for wildlife photography
07-16-2016, 07:16 AM   #22527
Weevil's Avatar
Nice! Thanks for sharing... you have convinced me that this mount is better and more flexible than the Kirk window mount...
another question, when you drive, don't you have the lens/camera/mount in your way for driving ?
07-16-2016, 08:12 AM   #22528
The lens/camera/mount is not really in the way I only use up tracks not main roads. Also because the ballhead is mounted on a slotted hole the camera/lens can be moved into the car
Just out of interest what is the measurement of the back edge of door glass on your car?
07-16-2016, 09:06 AM - 1 Like   #22529
Thanks for your responses - another addition to my wish list Eckla
07-16-2016, 09:22 AM   #22530
Weevil's Avatar
Thanks for your comment..
Sorry, I dont understand what to measure , You mean the height of the window opening ?
(may be a translation issue on my side)
« *Macro* lens club | - »
300mm, 300mm plus lens, 560mm, beach, birds, canada, chickadee, club, coast, couple, dogs, feb, flickr, friend, gulf, half, lens club, lenses, love, moon, pentax lens, pm, post, scene, sea, series, shore, shot, sigma, sunset, wife
Soviet lenses club Voe Lens Clubs 4034 1 Day Ago 11:36 AM
The Sigma Lens Club- All lenses Blue Lens Clubs 2731 5 Days Ago 06:01 PM
Wanted - Acquired: Long lens >300mm in K-mount pop4 Sold Items 1 10-03-2010 03:03 AM
Pentax DA 55-300mm vs Tamron 70-300mm at long end (brickwall) tcdk Pentax SLR Lens Discussion 17 11-15-2009 12:52 AM
All times are GMT -7. The time now is 08:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
