Originally posted by UncleVanya Is the consensus that the base lens should be a 300 plus focal length or should the adjusted length including Teleconverters be the basis for inclusion since this is the actual focal length.
Also I assume it is intended to be 300mm not including crop factor.
At 22000+ posts its kind of late to ask this question, isn't it? I always assumed that as long as the 300mm was optical, and what's the difference between a lens on its own or one with a TC, except that the teleconverter group is detachable as opposed to built in.
Crop factor is a diffent beast, for me, since most of us who shoot wildlife crop images any way, crop factor is irrelevant, except to the percentage of frame thrown away
---------- Post added 07-27-2016 at 07:13 AM ----------
Originally posted by dewolf my apologies if i screwed up trying to make a new thread. I just couldn't find a new thread button to press.
I purchased a new DA* 300mm F4 2 weeks ago.
Knowing that my other lenses needed some AF fine tuning I ran this new lens through the 2 calibration test charts.
Using a sturdy tripod, good light and a 2 second timer I started with the chart tests.
The first chart, at a 45 degree slope always showed back focus from -10 to +8. but was nearing normal at +9. whereas +10 was blurry.
The second chart, a flat wall mounted high contrast with some texture seemed to baffle all reason.
It was sharp at +1,3,4 6 and 9 and soft at all others. +5 was sharp in center, soft at edges.
all shot at F4.
So basically same sharpness at +1 and +9. How can this be ? faulty lens ? or something wrong with the camera ?
I get fantastic sharp pics on the DA 55-300, but it seems random on the DA* 300. I can get a refund but no replacement as the price went up.
suggestions ?
Dewolf
I assume it is with the centre spot focusing?
What is your shooting distance and what is the texture? It might be a question of exactly what the camera focused on and the depth of field at the shooting aperture that gives this appearance, also note that there is some hysteresis on auto focus, it is never perfect, it is a range of good enough. Therefore, try multiple shots, alternately focusing from minimum or maximum, and look for the best compromise
For me, I rarely do focus adjustments, I use the lens first, and see how it performs, then if I really think it needs adjustment I go back and do it. Personally i never shot a focus target in the field, so how it works on a focus target may be misleading.
