Originally posted by normhead I did some testing today... tripods set up maybe 2 feet apart both in the blind, taken at approximately the same time.....
One taken with the K-3 and DA*200 ƒ2.8
One taken with the K-1 and Tamron SP AF 300 f2.8
To normalize DoF, the K-3 was shot at ƒ5.6 and 400 ISO
The K-1 was shot at ƒ8 and 800 ISO
The surprise from that was the K-3 had better noise and contrast.+
I don't get what photo is supposed to be what camera, but for both, I prefer the firt one. There a bit more dof (or maybe different focus???) on the second one, particularly visible on the crop and there seems to be more sharpening too. I think overall the exposure is slightly different and that may explain a good part of the difference. The second set is darker.
Other than that, FF vs APSC is 1.3 stop difference comming from the sensor size looking at full photos. That's what theory says.
But you closed down one stop more for the FF so in the end, there only 0.3 stop difference, theoretically. Noise is still much lower on the first set, I don't know if that supposed to be K1 or K3 but the most obvious difference is the overall exposure and constrast is lower on the second one.
For the 100% crop, there no longer as much difference because you look pixel per pixel, so that come only from photosite size. K3 one are a bit smaller so there basically 0.2 stop difference in favor or K1. But because you used 800 iso vs 400 iso, the FF get penalized by 0.8 stop on a 100% crop so in theory it should look worse.
The FF gain for high iso is made at the expense of smaller dof. This is just how it is.
