Originally posted by derekkite Norm, why do you normalize the fstop for DOF? The physical measure of the depth of field is the same on both sensors, what changes is the relative DOF in the field of view. If your bird is in focus, the depth of the subject, no need to close the aperture.
The issue it you will have wider DoF on a 200mm lens than a 300, I've demonstrated this to myself a number of times. Shooting at the same distance, the 200 will give you more DOF. With these small bird, this close to the lens, DoF is often the determining factor in the acceptability of the image. The vast majority of the images are tossed because the bird does not align parallel to the focal plane leaving som apart of the bird out of focus.
Unless you are going for this look
IN images like this, a very small turn of the head or body will cause part of the bird to be out of focus. The DoF is so thin there is very little room for error, but, being this close is what gets me the detail. This is one of those rare shots when the whole bird is inside the thin DoF. But, if you increase your f-stop you slow your shutter speed, and start losing shots to motion blur. It really is a fine line I'm walking here.
