Originally posted by KevinR . . . and tube-extensions to reduce minimum focus distance.
Not only does it reduce the
minimum FD, it also reduces the
maximum focusing distance and limits the
total focusing range.
You can use this to your advantage when a close-in subject is allowing the AF to break lock and search throughout the min-to-inf range. Spreading a limited focusing range across the full rotation of the focusing ring also adds a degree of fine-tuning capability for both auto- and manual focus lenses.
I routinely take advantage of this characteristic by using 10 - 50mm of extension on 90 - 300mm lenses even when not interested in the extra magnification or close-ups although there is a slight EV penalty. The effect of extension rings on the focusing range is a useful tool not offered by TC's or macro lenses in general.
H2
Edit: from later post --
OBTW, since most extension tubes (PK) don't have the necessary data contacts for AF, a converted screw-drive PK/A or Pz-AF TC shell is required for AF.
With manual focus it seems much easier to finesse the view finder which is how I normally use this technique but it'll work with CIF too. I don't find it particularly useful with AF but it does work. (I.e., the DA 50-200 on hummers with a Pz-AF 1.4 TC.)
Let's say a given bare tele-lens focuses from 9 ft to infinity with the focus ring covering 270-degrees of rotation. With an extension it might focus from, say, 5 - 55 ft. Since the mechanics of the focusing mechanism haven't changed, each degree of rotation now covers only a fraction of its original range -- in effect, fine tuning the focus adjustment.
Since it takes the same amount of mechanical rotation to cover the full range of the
available field of focus there's no actual AF speed advantage if it actually breaks lock and hunts lock-to-lock but IME it seems that it's less likely to do so. Since small details cover a larger area at closer range there's less 'distraction' and a larger target for the AF system.
Normally we think of extension tubes as a close-up device but here we're also using the longer end of the focusing range. Try it on your next backyard safari, you might find it interesting.
