Originally posted by cooldude14es
Would the tripod mount on the F* version be a key factor for choosing it before the FA* version? Would you discard the FA* for not having the tripod mount that F* and DA* versions have?
Some people seem to find quite weird to use the FA* 300mm because they find the whole system quite unbalanced when mounted on a tripod.
What do you think?
For me, who is lucky enough to have three F* 300/4.5's (two used quite a bit, with one serving as a backup), I could almost just as well own FA* 300/4.5's. I almost never use this lens on a tripod (and, in fact, I can't even remember the last time I even put a tripod mount on one of these lenses), so the tripod mount presence or absence has never been as important to me in effect as my mind thought it would be.
More important to me is the hood design - I ~really~ like the way the built-in, sliding/screw-in-screw-out hood works on the F* (as opposed to the more typical separate hood of the FA*). The F* hood is ~always~ there (I don't have to worry about remembering to bring it, or worry about losing it), and, when it's extended, it's about as ~solid~ as a hood can be.
However, the FA* design does have its advantages, too. I guess that the transition from mf to af and back is better in the FA* lens (although someone else will have to chime in with what the difference is - not having ever handled an FA* 300/4.5, I don't remember what the difference is - <g>. And, I have heard that the silver finish in the FA* is tougher than the tan finish of the F* (not terribly important to me).
[Further on the tripod mount, there have been one or more 3rd-party mounts (that fasten with adjustable straps, I guess) that have been reputed to work on the FA* lens (although I am not sure about how they work). And, the "official" tripod mount for the F* is a bit of overkill, much taller than it has to be. (The shorter tripod mount for the A* 200/4 Macro, even though it's black, makes, IMHO, a better tripod mount for the F* 300/4.5 than does the stock mount.)]
So, I am happy with owning F* 300/4.5's, but I would not hesitate at all to recommend to someone that they should buy an FA*, especially if hand-holding were going to be the main use.
