That was just a cross-post with my own short answer…
Originally posted by Ron Boggs So great to see Lee shooting sharp shots...YEAH!
Regarding filter choices...Ben points out the glass thickness issue, to which I will add the glass placement issue. Some filters hold the glass closer to the front of the filter ring, others closer to the back or male threaded end. Just as glass thickness can effect the optical formula, so too can the front or back mounting placement of the glass within the rings. That's why I recommend the Pentax SMC filters as they are presumed to be tested to work.
If Pentax did not provide a filter for the filter holder, I must confess, I would expect the lens to work without one. At least they should have included info on exactly which filter would be be required for any specific lens.
Originally posted by Ron Boggs We may be overthinking this issue however, based on the discussions above. And I must admit, when I had the A*300/2.8, I purchased a few B+W filters for it. Those standard filters had such thick rings that the drop-in drawer wouldn't drop-in with the B+W filters in place. No problem...I just filed the filter rings down so they would fit. Note that this didn't affect glass thickness nor placement. Nowadays, many filter manufacturers offer slim versions of their filters for use with vignette-prone wide angles. If anyone is going to try B+W filters for the drop-in, I recommend the slim models so you don't have to use a file like I did.
Yes, the dimensions of the filter mount can be a problem, as I experienced myself, when searching for a drop-in filter for my Tammy 300/2.8. Some did not fit into the narrow slot. Filing down is a simple solution and works nicely.
Originally posted by Ron Boggs The FA* lenses with drop-in filter holders came with a filter kit so you can be assured that the filters are correct for that lens. The A* lenses did not ship with filters included, thus presuming you would simply screw in a Pentax filter. From the current discussion, there may be enough tolerance regarding precise glass placement that the precise filter may be less important than simply having those surfaces (front and back of the filter glass) somewhere in the drop-in area of the light path as it goes through the lens?
Positioning of the filter in the light path should, as you rightly pointed out, not be obverlooked. But I think, with these long focal lengthes, we are talking about, the slight misplacement due to different filter mounts should be within acceptable margins of error. Glass thickness is much more important. It would be different for wide angle lenses, though, or basically any lens with a less parallel bundle of rays, unless its construction is near telecentric.
Originally posted by Ron Boggs Regardless, the lesson here is if your lens has a drop-in filter drawer, you should probably keep a filter in it!
Hm, I am not convinced this is an automatism. For instance there has been the first Tamron 300/2.8 (107B) perfoms better without the filter in place, because the filter seems to introduce spherical abberation. Tamron engineers designed the lens, without the filter in place. I also think, the old Pentax K 500/4.5 was designed withou the rear filter (filter changing on that lens is a nightmare). I would think, sometimes they simply added a slot (or a gelatine holder in the case of wide angle lenses), to allow the use of smaller, cheaper filters and did obviously not take into account the function as an additional refreactive element in the light path.
Ben
