Show Printable Version 91813 Likes Search this Thread
03-05-2020, 03:15 AM - 6 Likes   #32986
QuoteOriginally posted by weverka Quote
1200mm times 1.4 is not 2520mm. What am I missing?
1200 X 1.4= 1680 +1.5 crop factor = 2520 in 35mm terms.
More Short Eared Owl shots with my K-5/Sigma 800mm F5.6 APO EX/Gitzo 5532LS
03-05-2020, 03:58 AM - 8 Likes   #32987
Trissa's Avatar
QuoteOriginally posted by WPRESTO Quote
With that focal length you're in the realm where a mosquito flying past will generate wind causing the lens to vibrate as if there were an earthquake.
Sometimes a good tripod could help
this is a crop out of the big picture:
The biggest issue is the big city directly "under the moon" with millions of lights and in wintertime the hot air from the heaters going up to the sky. That's one of the reasons that the lower part of the moon is more unsharp than the upper part.
---------- Post added 05-03-20 at 12:12 ----------
QuoteOriginally posted by Ducatigaz Quote
As the pixel size of the K5 is nearly the same as of the K1 the crop factor can be neglected - if you compare pictures of both cameras. The only issues you will observe is, that the moon does not fit on the sensor of APS.C with 2m lenth. When I took the picture of the moon I had to turn the K1 by 90° to get the complete moon in one image. But at full moon this will not be enough.
But sometimes 400mm is also sufficient
03-05-2020, 04:28 AM - 1 Like   #32988
MossyRocks's Avatar
QuoteOriginally posted by Arjay Bee Quote
Thank you for the description, can you post a photo?
There was a link to the thread for it but if you want here is a new link to the thread over in the astro group for it.
Ahhh, that would explain why no one has done it before. What about the other bits of junk left behind? Or the tyre treads from the lunar rover - or will they have all been obscured by now by surface impacts and resulting dust movement?
I think again that most of it is all too small and even with perfect conditions would be eaten by the diffraction limit of a lens. Even trying to photograph something much close like the ISS the diffraction limit kicks in the best anyone has ever managed around here for imaging it is this. If you read through the entire thread there is a stacked imaged of the ISS created from the 12 captured frames. With stacking and processing we were basically hitting the diffraction limit of his gear so going much further out like to the moon the angular size of even big things from earth would end up putting them well under the size of what could be resolved with ideal equipment. Again that ignores the 100 miles or so of turbulent atmosphere before you hit about 240,000 miles of space.
Diffraction at f/20 is a killer.
03-05-2020, 05:05 AM - 6 Likes   #32989
K-S2 and DA*300, handheld. I think I'm pushing the limits a bit here, not only with the lighting and my own technique but possibly the system as well. Could I do more in PP?
03-05-2020, 07:29 AM   #32990
luftfluss's Avatar
QuoteOriginally posted by Shedking Quote
Given that there is no EXIF available for the photos, it's hard to advise...
03-05-2020, 11:13 AM - 6 Likes   #32991
jacamar's Avatar
Down by the riverbank everything is quiet and peaceful....
and then it's not.
03-05-2020, 11:19 AM   #32992
Brrr, scary creatures. I'd be off in a hurry as well! Great timing on your side though!
03-05-2020, 12:29 PM   #32993
QuoteOriginally posted by luftfluss Quote
It was only ISO640 to get 1/800th @ f/6.3, then a x2 crop, but I don't like the OOF areas much at all. Photoshop has more filters than I know how to use - perhaps one of the Blur options would have improved the result?
03-05-2020, 12:52 PM   #32994
Arjay Bee's Avatar
QuoteOriginally posted by MossyRocks Quote
Thank you for the relink - a very interesting series of posts at the two links, and i now have a better understanding of the limits of this type of image. Aalso
i have learned that you cant believe everything you see portrayed in tv shows where if you have the gear you can zoom into anything.
03-05-2020, 01:25 PM   #32995
MossyRocks's Avatar
Maybe. Good picture shooting technique is very much like good actual shooting technique. There was a thread a little while back where someone went over in great detail how good rifle shooting technique is really the same as good picture shooting technique but I can't find it.
Probably, but going beyond the simple sliders in Adobe products has a big learning curve
I don't know what settings you were using but I would assume you were referring to reducing the noise in post processing. It looks like you did very little and a while back I gave someone else's image a good try at noise reduction over in the critique forum. If you want to see what was done there you can look here.
03-05-2020, 02:44 PM - 6 Likes   #32996
One of the dogs we used to dogsit for at the time.
K5 + FA*300 f/4.5
Cross-posted in Your Pet a Day.
03-05-2020, 05:12 PM - 4 Likes   #32997
Aaron28's Avatar
only had a few chances and blew them with over exposure....Madison county lake, alabama….K-3ii....sigma 150-500os.....x posted where relevant
03-05-2020, 06:52 PM   #32998
luftfluss's Avatar
QuoteOriginally posted by jacamar Quote
and then it's not.
This is meme-worthy
03-05-2020, 07:06 PM   #32999
Northern Saw Whet Owl, K7 300mm f4.5
Taken several years ago.
03-05-2020, 07:17 PM - 2 Likes   #33000
luftfluss's Avatar
I often use a light amount of noise reduction in my images, and sometimes selective sharpening. In my experience, the blur filters in Photoshop often wind up making the image look artificial, because the areas where the blur is used look noise-free while other areas (like the subject) have more noise in comparison.
Sometimes you can clone out part of the background and then try to subtly soften it. I hope you don't mind me mangling your photo a bit I cropped off some of the right side, then removed the branch with Photoshop's "clone" tool. I then masked the background sky area and went into Camera Raw and applied -20 Clarity. I then went back into Camera Raw and reduced the overall exposure of the photo by -.15 and reduced "Whites" by 20, and finally added a vignette of -30. IMO this de-emphasizes the background fairly naturally and makes the beautiful bird pop a bit more... of course you may think it's all rubbish and I wouldn't be offended if you do!
300mm, 300mm plus lens, 560mm, beach, birds, canada, chickadee, club, coast, couple, dogs, feb, flickr, friend, gulf, half, lens club, lenses, love, moon, pentax lens, pm, post, scene, sea, series, shore, shot, sigma, sunset, wife
The Sigma Lens Club- All lenses Blue Lens Clubs 3237 12 Hours Ago 07:23 AM
Soviet lenses club Voe Lens Clubs 4208 2 Days Ago 03:41 PM
Wanted - Acquired: Long lens >300mm in K-mount pop4 Sold Items 1 10-03-2010 03:03 AM
Pentax DA 55-300mm vs Tamron 70-300mm at long end (brickwall) tcdk Pentax SLR Lens Discussion 17 11-15-2009 12:52 AM
All times are GMT -7. The time now is 07:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
