Originally posted by smc I can attach the camera directly to the tube using a single adapter? This would limit pictures to the focal length of the tube but would give me the best quality?
I can attach the camera with lens attached via the filter thread using another adapter? This would give greater magnification but would reduce light and quality?
Thanks,
It has been a while since I attached a camera to my telescope, but I have two adapters.
1) k-mount to telescope adapter: This looks like a thick k to m42 adapter for old lenses. (In fact, it works on m42 lenses, but like there is a short extension.) This can be screwed directly onto my telescope so the telescope becomes a lens. This may not work for all telescopes. Mine it a refractor telescope, which is just like regular camera lens. Reflecting (mirror) telescopes may be different.
2) Variable-projection camera adapter (according to the box): This screws into the adapter and then you can attach it to the telescope just like a regular eyepiece. You can also insert an eyepiece into the adapter for greater magnification.
Neither adapter is from Pentax. The first is unknown while the second is from Meade.
There are likely other adapters you can get as well; I am far from an expert. I did find this site:
DIGITAL CAMERA ADAPTERS FOR TELESCOPES - Largest Selection!
Here is a sample picture of the moon with the camera directly attached to the telescope:
The telescope is 1000 mm and the picture taken with my k7.
Hope that helps.
Aaron
