Originally posted by MSM Thanks Peter. I was wondering if anyone kept their K10d in permanent Debug mode. I guess that there is no harm in that. You do get that screen with 'Debug Mode' all the time, though.
My problem is getting the adjustment for each lens. Do you use a Lens Align product? What is your system of adjusting? The more I have looked into micro adjustments, the more I feel I don't know and I fear that I may be making things worse. I really would like to have my DA 35, FA 43, and 77 adjusted. It looks like 120, 130, 130um, respectively.
you do get the screen on, and saying Debug mode, all the time but you'll get used to it, and the battery life seems to be fine too,
My technique for getting the adjustment right? One bank statement, tripod, cable release and 2sec mirror lock up. I set the lens to what I think it should be, and then take series of shots 5+ and 5- with 10um respective adjustment, and compare the results, I settle on one and go to real life shots, if unsure, I repeat the test on bottle of conditioner, or shampoo or whatever else is available, repeat this with each lens, and sometimes even 3-4 times to make sure it's what it should be.
BR
Peter
