05-28-2021, 06:01 AM   #11251
Digitalis's Avatar
It is probably a good thing they are doing a refresh of the FA limited lens line rather than an outright re-design with Ultrasonic motors - it means replacement parts for the AF drive chain will still be made.
05-28-2021, 07:59 PM   #11252
RobA_Oz's Avatar
It may also mean that in-body AF drive will continue in new bodies for a while yet.
05-31-2021, 08:04 AM - 3 Likes   #11253
Jonathan Mac's Avatar
43mm
Crumbling castle
by Jonathan MacDonald, on Flickr
06-01-2021, 11:14 AM - 3 Likes   #11254
ehrwien's Avatar
SMC FA 43 on K-1
Flowering Tree at Sunset
No picture to pixelpeep as this was taken handheld and wide open, but I really like the feel of it. I think the colour gradient in the sky is a fitting background for the tree's blossoms
06-01-2021, 11:52 AM - 3 Likes   #11255
Jeff's Avatar
Windsor Great Park and the smc 43mm f/1.9
... a walk with one of my favourite lenses. I love the focal length and the rendering of the bokeh.
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
06-01-2021, 12:33 PM   #11256
QuoteOriginally posted by Jeff Quote
I agree - I've always liked the bokeh on the 43 and wouldn't change it for the new HD version with more rounded aperture blades. Great photograph - really like it!
What I've found regarding the bokeh of the FA43 (straight blade version) is that while it CAN be a bit busy sometimes (which I personally don't really appreciate), nevertheless a lot of the time, the bokeh ISN'T busy. I guess it depends on the interplay between factors such as the type of background, distance of background, the aperture chosen, the shooting angle, lighting etc.
And I really love that bokeh! It's something special, and beautiful! It's got a character to it, something like a fine grit or texture to it, which I really appreciate and value.
I don't know what causes it to be so, but I've long suspected that the straight blades may have something to do with it.
And if that's true, and if the new rounded blades take away this texture/character from the bokeh, yielding instead bokeh that's merely "smooth", personally speaking I don't think I'd like that. I prize the present bokeh character of the straight-blade FA43.
---------- Post added 06-02-21 at 04:40 AM ----------
My fa77 F/1.8 limited developed a crack in the main AF drive gear*, which caused the entire focus ring to seize up:
Fortunately, the entire assembly is able to be ordered in and I was able to restore the lens and now the focus ring turns smoothly once again.
Pentax KP - SMCP-FA77mm f/1.8 Limited.
* Which are made of what I take to be Brass: which is a bit perplexing as I thought the entire idea of using that metal was to avoid corrosion and cracking.
I too had the unpleasant experience of the focus mechanism jamming, the focus ring unable to turn, with a mild "crunching" feeling. It happened to my 77, and then 43.
The authorised Pentax repair staff told me that in both cases it was the same problem ó a cracked gear inside the lens.
I'm not sure if it was exactly the same gear as you showed in your photo, but I suspect it would be.
Fortunately, it was quickly repaired, and relatively inexpensively.
06-01-2021, 01:36 PM   #11257
RobA_Oz's Avatar
The appearance of the metal suggests it might be a sintered pressing, rather than machined from a blank, but itís hard to be sure about that from the one photo. Otherwise, that sort of radial cracking implies a tolerance issue in the fit between the gear and the shaft. In any event, speaking as an owner of the three FA Limiteds, thanks for bringing it to our attention.
06-01-2021, 10:01 PM   #11258
Digitalis's Avatar
QuoteOriginally posted by RobA_Oz Quote
I concur, the surface texture and colour of the metal does appear to be different from the other gears present, and the location of the crack does support this. Machining such a small gear from common stock would be difficult as there are many methods of forming metal each with their own particular pros and cons.
06-02-2021, 01:36 AM   #11259
QuoteOriginally posted by KDAFA Quote
This sounds like what happened to my DA 40mm.
06-02-2021, 05:31 AM   #11260
QuoteOriginally posted by Jonathan Mac Quote
I'm sorry to hear that.
I'm assuming that by DA40 you meant the Limited lens?
It would appear then that this happens not just to FA Ltds but to DA Ltd's also..... ?
Thanks for the tip, I'll be keeping an (uneasy) eye open now, for my DA Ltd 15 & 35.
Wondering whether other DA Ltd owners here have experienced this sort of jamming as well?
06-06-2021, 01:59 AM   #11261
Jeff's Avatar
In my garden...
I know people talk about the 3D rendering of the Limiteds, and so I made this photograph with my brand new smc 31mm to see if this was even a bit true, and yes, it is...
PENTAX K-1  Photo
06-07-2021, 07:00 PM - 2 Likes   #11262
Aaron28's Avatar
past weekend's meet & greet.....K-1....fa43....af360fgz....cactus v6ii.....crappy sky replacement via luminar4
06-08-2021, 02:33 AM - 3 Likes   #11263
Transit's Avatar
FA 43 ltd @f6.3
Aussie hardwood
PENTAX K-1  Photo
06-08-2021, 05:54 PM   #11264
dbs
QuoteOriginally posted by Aaron28 Quote
The cars and model .... what there is a sky
06-08-2021, 09:25 PM   #11265
Aaron28's Avatar
QuoteOriginally posted by dbs Quote
what there is a sky
the sky was completely blown out white......replaced a fake sky via luminar4
asph, bit, color, contrast, da, eye, f/1.8, fa, fa77, flickr, forks, idea, image, k3, lake, leaf, lenses, lol, ltd, moon, pentax, pentax lens, post, spoon, sunrise, thanks, third, tucker, vision
The FA Un-Limited Club cbaytan Lens Clubs 642 22 Hours Ago 02:55 PM
The DA Limited Club legacyb4 Lens Clubs 5721 1 Day Ago 11:49 AM
I'm thinking about joining the Limited club Damn Brit Pentax SLR Lens Discussion 60 02-01-2010 12:27 PM
For Sale - Sold: FA limited 43mm/f1.9 (black), FA limited 77mm/f1.8 (silver), FA 28-105mm/f3.2- chemxaj Sold Items 24 10-16-2008 11:17 AM
For Sale - Sold: smc Pentax-FA 77mm Limited & 43mm Limited MikeH Sold Items 2 02-13-2007 06:03 PM
All times are GMT -7. The time now is 01:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
