Originally posted by NaClH2O That is simply a marvelous shot Digitalis. Do you mind telling us how you set it up? Obviously your head is behind the lens, but that is all I can figure out.
NaCl(Enquiring minds would like to know)H2O
Originally posted by steve1307 For doing a self portrait...... there's a mirror involved (check the lettering).
I'm going to try this out... but I only have an M50/1.7 so will need a longer arm, or maybe a smaller head
correct, I used a mirror to set everything up. I also will point out that the smaller the f/stop of the lens is the closer it will have to be to the camera/mirror when you take the shot because the image in the lens will be smaller.
I did a version of this image with the new Leica noctilux 50mm f/0.95 ASPH but I needed more than two fingers to hold that monster up (at $12,000AU I really did
not want to drop a lens that expensive) I liked the version with the 50mm f/1.2 because it is simply my favourite lens in my entire collection of pentax glass.
I used a Single wireless AF540FGZ flash with a sto-fen diffuser at my lower right to illuminate my face and hand. As Steve pointed out I used a mirror to align my face in the lens and I used Live view on my K-7 to check on my composition. The camera was of course tripod mounted, It only took me two frames to get it right I was most concerned about how my hand would appear. All I did in post processing was flip the image, and sharpen and convert into monochrome.
