Originally posted by excanonfd Doesn't the PZ-AF converter play havoc with aperture reading on A type lenses, my 2x TC shows maximum aperture as f1.2 with the 60B. Has anyone figured out a way to make the combination report at least the lens' maximum aperture?
I have one Pz-AF 2x and two Pz-AF 1.4 converters and half a dozen PK - PK/A adapters -- all operate "normally" with both Pentax and Tamron lenses on *istDS, K100DS, K200D and K10D and older film bodies. Four of the five PK/A adapters work as advertised. (One older one doesn't report less than f 4.0 and I've CLA'ed 'em as best I could).
Having said that, I have to admit I really don't care so long as the lens sets a reliable and consistent aperture relative to the exposure value
I select regardless of whether that's through in-camera AE, manual stop-down mode or manual via a Pentax Spotmeter metering. I simply evaluate the first shots (pre-shots if possible) and adjust as necessary. (Smiling as I go while remembering the days when mistakes weren't discovered until the film was wet.)
Regardless of the mode, I normally select aperture out of old habit unless shutter speed is a priority. From use, I know for instance that the K10/360B combination over exposes spot metering by 1 1/2 - 2 stops and compensate accordingly. Why that is? I donno; it's pairing issues I suppose. I could figure it out and "place blame where due" but it's simply easier to take the path of least resistance, acknowledge the peculiarities and forge ahead with chimping as a useful tool.
Logic and experience tells me it's a loosing battle to expect absolute standards from 30+ year old analog, electro-mechanical adapters.
Repeatability is comfort enough in this case. Life's easier this way and lazy, thoughtless failures keep one humble and disinclined to bitch about the gear.
H2
