Originally posted by Transit Nothing wrong with the [SP] 300/5.6
Even the older CT-300-class lens is still useful. When I acquired a
Tamron-F 300mm/f5.6 in fixed-OM mount at a price I couldn't resist, I removed the bayonet mount plate and OM linkage and simply
epoxied a spare AD-2 PK adapter in its place.
I didn't shave the lens base to match the Pentax registration distance to retain infinity focus; instead I intentionally took advantage of the slight extension tube effect to build a short-range, backyard bug, bird and squirrel shooter. It works just like an M-class lens.
The result was a dedicated close-focus lens with a useful range of approximately 5.5 - 50 feet and the decent optical qualities of the Adaptall CT-300/f5.6. Had I realized then how useful it was going to be, I'd have added an additional extension tube spacer to further promote the macro effect.
It's light weight, easily hand-held, and works as well as can be expected with cheap PK TCs and extension tubes. It became a pseudo- SP 300/f5.6 "macro" for under $25!
It's truly an Adaptall in spirit if not in pedigree. That adaptation re-cycles a cheap, fixed mount lens from some of the abandoned film mount lenses available today.
As one benefit to using a "long-macro" setup, I'd note that a strobe is more versatile, easier to position and to diffuse the fill light and
much less annoying to use at 5 - 10 ft than at 5 - 10 inches. It also compensates for the slower maximum aperture by making additional DoF and higher shutter speeds available at f8-22. It makes a perfect match for an old *istDS with an older high-power TTL strobe as I tend to use it.
H2
