Originally posted by derekkite Look for a PKA adapter. It gives you automatic aperture control, ie. you set the aperture you want on the camera body and it does it with a mix of magic and mechanical bits on the lens. If you want my opinion, they aren't worth it. Get an inexpensive PK with no mechanism on ebay, around 12 bucks or so.
I have noticed you are very down on the PKA adapters, calling them flimsy and so forth. I do have one that doesn't work right, and another that is a bit flaky, but they were like that when I bought them. I have several others that have always worked correctly, and I have taken the on and off lenses more times than I would like and they are still fine. So while they aren't the most reliable things in the world relatively speaking, they aren't THAT flimsy, and if you take care with them there is no reason that they probably won't keep working fine. (And if they break they more than likely will still work as PK manual adapters.)
Having a fully working 'A' lens does have a lot of advantages, so I'd just thought I would advocate for the position that the PKAs *are* worth it in some circumstances. Using manual bayonet lenses on my K-01 annoys me a bit, for instance, since you can't dial in EV compensation in M mode (with a non-'A' lens) like you can with more full-featured models, seriously compromising the usability of green-button metering. And I find the Adaptalls often need an Ev adjustment. Using a 'A' lens makes using flash much easier also...
