Originally posted by pacerr Removing the rear element group may be easy in many cases but it can cause focusing problems it isn't re-assembled properly. A little tweaking can fix it but it can be time consuming if you don't have test bench tools and charts.
It pays to scribe an index (witness) mark near any threads to aid in re-assembly. Especially when you remember to do so BEFORE you initially remove an element!
I've acquired a few problematic lenses that only needed properly seating or adjusting the rear element to recover from a lack of focus / sharpness.
Pacerr,
It seems the 02B and 04B's rear elements can be easily removed / reinstalled. Can you explain what exactly you mean by index (witness marks). After I removed the elements and re-installed them the lens seems to focus and be just as sharp as before.
I made sure all the elements where securely in place and the spacer rings were properly in place.
---------- Post added 03-13-15 at 11:55 AM ----------
Originally posted by marcusBMG mmm something like that, always a bit of a mystery as to how it might get in but I have had lenses with similar things, and even dead dust mites though they can move and grow. If its bugging you then its not difficult to remove the front element with a lens spanner and brush/blow it away, however since this will not affect your pics I suggest just ignoring it.. (some perspective
here ).
So it turned out to be some sort of debris stuck to the back side of the third inner front element on the 04B. I removed the two rear elements from my 04B and used my rocket blower to blow air into the barrel from the rear. That seem cleared it up.
Now my 04B and 02B are back in business!
